Hi all, As I want to use SPI, I made a patch to adjust the mach-mini2440.c file see attachment). My series file contains 1 entry : patch. After compiling the kernel I have a spidev0.0 device. However the touchscreen is unusable as well as the framebuffer. Also a wrong lcd display is selected (wrong resolution). the config in the boorloader is correct. During boot there are several messages : f.e. 't' ignored, touchscreen not compiled in When I compile the same kernel without patch everything works (no spi). Any idea what I am doing wrong ? Kind regards Luc
pengutronix BSP: no touchscreen when applying patch
It seems you are using a plain vanilla kernel, as the code looks like this:
case 't':
printk(KERN_INFO "MINI2440: '%c' ignored, "
"touchscreen not compiled in\n", f);
break;
So, the touchscreen feature is not implemented.
