hello, I am trying to take video input tvp5150. Did anybody succeeded with this? I have tried with factory installed Android 4. any help in this regard will highly appreciated, thanks
tiny210 camera input through tvp5150
Yes, Previously on OMAP3 board. I think this camera is not well implemented in android 4, I will downgrade to 2.3 and try it. Yesterday I have tried with both NTSC and PAL camera, always got "Camera is not responding" still need to check kernel log... :(
First check for the tvp5150 driver in android 4 kernel. I don't think it has driver for tvp5150. Even if you downgrade to 2.3, at first place you should have the driver.
Nitin, Yes I have checked the driver is not there, I have been trying to downgrade android2.3, but the procedure is very different from previous friendlyarm boards. I have to check for driver first and then recompile kernel if it is not there. :(
I have a strange problem now for compiling tvp5150 driver in android kernel, I have added following line in kernel configuration file mini210_android_defconfig CONFIG_VIDEO_TVP5150=y then cp mini210_android_defconfig .config make the driver or kernel module is not built, no tvp5150.o in driver source directory, and also no CONFIG_VIDEO_TVP5150=y in .config file, even it does not appear in make menuconfig :(
I got it work by using latest kernel binary images from 3 march product dvd , :) PAL working fine, NTSC gives complete image with some distortions, little frames drop is also there.:( and image is reverse, (top part is showing in bottom)
Hello I am using Tiny210 board and I would like to manage video from analog input . Where I can find little example code using tvp5150? Thanks
Pratik Did you use tvp5150 in omap3? I don't know how to use this with ARM
A8 Cortex (Texas Instruments AM3517) I configure tvp5150 in my i2c-2 bus.
static struct i2c_board_info __initdata i2c2_boardinfo[] = {
/*Video Input */
I2C_BOARD_INFO("tvp5150", 0x5c),
.type ="tvp5150"
i2c_register_board_info(2, i2c2_boardinfo,
ARRAY_SIZE(dinitel_i2c2_boardinfo));
But I cant find the device in /dev. How can I acces to it?
Thank you.
