Hello People, I've been using 2440 board since a long time, A friend of mine wants to use ADC of the baord for his college project. He wants to use 4 Analog input of this board. I've explore the diagram and found there are sufficient Analog input on the board but I can use only one ADC pin that is AIN0 out of 4. What should i do If I wants to use all AIN pin? Your Help will be very helpful for me to move ahead with this project. Thank you for your time and consideration. Look forward to hear from you soon. Regards, Peter
wants to use other AIN pin
Hello, Which BSP do you use? If you are using FriendlyARM BSP, the driver is written for AIN0 only. If you want to use other ADC channels, you have to modify the driver or write your own one. If you use Juergen BSP (Pengutronix one), they are all already available by default. Regards, Screwface
@Screwface, Thanks for the prompt reply, Yes I am using Friendly ARM BSP, I've compiled Juergen BSP for giving linux 3.1 a try, but will try 3.1 again. BTW, that BSP has all are available by default, but how can i use all other? do i need to write the driver for the same as like Friendly ARM BSP provide for default AIN0? or one driver will be sufficient for the all? can you please let me know? Thank you for your time. Regards, Peter
a) connect your sources to pin 5,6,7 or 8 at CON4 (check voltage levels!) b) read from the hwmon sysfs entries the converted values (open(), read(), close()) That's it.
@Juergen, Linux 3.1 is up and running, but I am unable to find the /sys/ interface for the same, can you please tell the exact sysfs entries to watch? ls /sys/devices/platform/s3c24xx-adc/s3c-hwmon modalias power subsystem uevent these are the entries, which entries to watch If I am in right direction Or tell me the correct path to look up the value for all other ADC pin. Thank you for your time. -- Peter
Mine is looking a little bit different: root@mini2440:/sys/devices/platform/s3c24xx-adc/s3c-hwmon ls adc0_raw adc4_raw driver in1_input in3_input in5_input in7_input subsystem adc1_raw adc5_raw hwmon in1_label in3_label in5_label in7_label uevent adc2_raw adc6_raw in0_input in2_input in4_input in6_input modalias adc3_raw adc7_raw in0_label in2_label in4_label in6_label power
Hello Juergen, Wow, its working perfectly good for your, but mine is not working as per expectation. I am running Linux 3.1 compiled using Pegutronic, Please tell me what to do to get it working ? Do i need to attach a ADC Hardware or I will have this data once after Linux boot. Please guide me on this. Regards, Peter
If you use my Mini2440 BSP, it should be enabled by default. You can check, if in your kernel config the following defines are set: CONFIG_S3C_ADC=y CONFIG_S3C_DEV_HWMON=y CONFIG_HWMON=y CONFIG_SENSORS_S3C=y CONFIG_SENSORS_S3C_RAW=y
Hello Juergen, Thank you very much for your time, I've enabled hwmon and all value are now appear under /sys. Thanks a lot, Now I need to attach Hardware and need to monitor the value. Regards, Peter
Hi....... @Juergen How can i check these........ CONFIG_S3C_ADC=y CONFIG_S3C_DEV_HWMON=y CONFIG_HWMON=y CONFIG_SENSORS_S3C=y CONFIG_SENSORS_S3C_RAW=y regards Jack
These are variables used in the Kconfig buildsystem of the Linux kernel. If you use a plain kernel run "make menuconfig" to enable these variables, if you are using PTXdist, run "ptxdist kernelconfig" instead (both will bring you to the same Kconfig menu).
Hello guys, I've read that Peter had a success with adding hwmon feature to his /sys/... I tried the same approach with building my kernel with Juergen settings but not successfully. I'am using FriendlyARM mini6410 so there is maybe difference between kernel settings for 2440 and 6410. Does somebody have an experience with ADC on 6410? I'm getting crazy about this issue.. recompiling kernel all the time without hoped result. Thanks, Jan
To be able to use the ADC you need to: - enable the driver in the kernel - *and* register the ADC hardware at run-time Only if both is done, you will get the entries in the sysfs.
I gave up this way of launching ADC and currently trying to use ptxdist. So I will write down, how does it go. I hope that there are necessary patches already applied, because I'm not able to do it by myself. Thanks Juergen, Jan
Well, I had a success with ptxdist, so now I'm able to access ADC, perfect! Now I'm gonna learn how to add some other packages into filesystem, because I'm missing here some things like boa, ssh, ftp.. but I hope this will not be big issue. Jan
Just run "ptxdist menuconfig" and enable the other packages you expect to be present in your Mini6410 filesystem. After a "ptxdsit go" they will be present.
