Hi All, After buidling a rootfs and recompiling the kernel, the boards boots but there is no logo on the screen. My board has 7inch lcd. U-boot option is set to mini2440=1tb. But there is no activity on the screen. I have built a rootfs using busybox1.13.4 using following link. http://wiki.iface.ch/index.php/Basic_rootfs_for_Mini2440 http://code.google.com/p/friendlyarm/wiki/Linux_Tutorial Also recompiled the kernel with A70 configuration. I set the board to boot from SDcard as per this link http://bill.station51.net/index.php?post/2010/01/30/HOWTO%3A-Booting-fro... I have also attached a kernel boot log file. How to get the screen working? Can some one please reply. Thanks Tama
No logo on the screen while booting!!
And what did you get with my reply to your other post? http://www.friendlyarm.net/forum/topic/3845 There is more to come when you answer that question.
Hi Juergen, Thanks for pointing out mounting of sysfs. I managed to solve the issue now I can see the screen comming up with the logo and login in screen. While compiling the kerenl, backlight driver support and console on frame buffer was not enabled. There was also an issue with my init.d/rcS, fstab files and dev directory. Initially I followed this link "http://wiki.iface.ch/index.php/Basic_rootfs_for_Mini2440" to create these files. But I am getting permission error with /dev/null, /dev/ttySAC0.I wa manually creating /dev/tty .... etc. I even changed chmod 666 to all the nods in /dev folder. But i was still getting a error saying couldnt open <node> no such file or folder. Then I found another inittab script on "http://cchia-cwp.blogspot.com.au/2010/03/build-root-file-system.html". I even modified rcS script so that i creates the nodes and directories. How to assign different console to touch screen and serial port. my bootargs has console=ttySAC0,115200.
Hi Guys,
I am getting syntax error with tslib binaries when i install them on
mini2440
1) ts_calibrate: line 1: syntax error: end of file unexpected.
2) ts_harvest: line 1: syntax error: word unexpected (expecting")")
3) ts_print: line 1: syntax error: word unexpected (expecting")")
4) ts_test : line 3: syntax error: "(" unexpected
5) ts_print_raw: some unicode characters cant even read them.
I followed the link to compile tslib and qt.
http://mini2440vietnam.blogspot.com.au/2011/04/upgrade-qt462-in-mini2440...
http://billforums.station51.net/viewtopic.php?f=8&t=15&p=44#p44
After I run "./autogen.sh" on host pc I get following output. Is this
correct or some thing went wrong?
libtoolize: putting auxiliary files in `.'.
libtoolize: copying file `./config.guess'
libtoolize: copying file `./config.sub'
libtoolize: copying file `./install-sh'
libtoolize: copying file `./ltmain.sh'
libtoolize: putting macros in `m4/internal'.
libtoolize: copying file `m4/internal/libtool.m4'
libtoolize: copying file `m4/internal/ltoptions.m4'
libtoolize: copying file `m4/internal/ltsugar.m4'
libtoolize: copying file `m4/internal/ltversion.m4'
libtoolize: copying file `m4/internal/lt~obsolete.m4'
libtoolize: Consider adding `AC_CONFIG_MACRO_DIR([m4])' to configure.ac and
libtoolize: rerunning libtoolize, to keep the correct libtool macros
in-tree.
configure.ac:7: installing `./missing'
Then i ran
./configure --host=arm-linux --prefix=/usr/tslib --enable-shared=yes
--enable-static=yes
followed by make and make install.
Didnt get any errors.
Did i miss any step or the cross compile went wrong. Can some one please
help me to get tslib working.
thanks
tama
> 1) ts_calibrate: line 1: syntax error: end of file unexpected. $ file tests/ts_calibrate tests/ts_calibrate: POSIX shell script text executable > 2) ts_harvest: line 1: syntax error: word unexpected (expecting")") $ file tests/ts_harvest tests/ts_harvest: POSIX shell script text executable and so on... I guess you installed the "tests/ts_*" to your mini. PEBCAK. Use the "tests/.libs/ts_*" instead. Or run "make install" which shows you, what files are really have to be installed to your target.
Hi Juergen, Thanks for your tip. I installed files from /usr/local/tslib (host-pc) to mini2440 /usr/local/tslib. There is no such folder as .libs inside tslib/tests (host-pc). I recompiled tslib as I was not sure whether it was compiled correctly. After going through "http://billforums.station51.net/viewtopic.php?f=8&t=15&start=130...; My steps were as follows:=> 1) export PATH=/usr/local/arm/4.4.3/bin:$PATH export CROSS_COMPILE=arm-none-linux-gnueabi- export CC="${CROSS_COMPILE}gcc -march=armv4t -mtune=arm920t" export CXX=${CROSS_COMPILE}"g++" export AR=${CROSS_COMPILE}"ar" export AS=${CROSS_COMPILE}"as" export RANLIB=${CROSS_COMPILE}"ranlib" export LD=${CROSS_COMPILE}"ld" export STRIP=${CROSS_COMPILE}"strip" 2)./autogen-clean.sh 3) export ac_cv_func_malloc_0_nonnull=yes 4) ./autogen.sh 5)CC=/usr/local/arm/4.4.3/bin/arm-none-linux-gnueabi-gcc CFLAGS="-O0 -msoft-float -D__GCC_FLOAT_NOT_NEEDED -march=armv4t -mtune=arm920t" 6)CXX="/usr/local/arm/4.4.3/bin/arm-none-linux-gnueabi-g++ -O0 -msoft-float -D__GCC_FLOAT_NOT_NEEDED -march=armv4t -mtune=arm920t" 7)./configure --host=arm-none-linux-gnueabi --target=arm-none-linux-gnueabi -enable-static=no -enable-shared=yes -prefix /usr/local/tslib 8) make 9) sudo make install ------------------------------------------------------------------------- After make install tslib was installed at /usr/local/tslib (host-pc). I tested the binaries(/usr/local/tsclib/bin on host pc) as you suggested in earlier post. >file ts_calibrate >ts_calibrate: ELF 32-bit LSB executable, ARM, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.32, not stripped then I tried to read the libraries being used using readelf command ------------------------------------------------------------------------ root@:"$CROSS_COMPILE"readelf -a ts_calibrate | grep lib [Requesting program interpreter: /lib/ld-linux.so.3] 0x00000001 (NEEDED) Shared library: [libts-1.0.so.0] 0x00000001 (NEEDED) Shared library: [libdl.so.2] 0x00000001 (NEEDED) Shared library: [libc.so.6] 0001401c 00000c16 R_ARM_JUMP_SLOT 00008adc __libc_start_main 12: 00008adc 0 FUNC GLOBAL DEFAULT UND __libc_start_main@GLIBC_2.4 (2) 62: 00000000 0 FILE LOCAL DEFAULT ABS ts_calibrate.c 176: 0000b3ec 4 FUNC GLOBAL DEFAULT 13 __libc_csu_fini 179: 00008adc 0 FUNC GLOBAL DEFAULT UND __libc_start_main@@GLIBC_ 233: 0000b3f0 112 FUNC GLOBAL DEFAULT 13 __libc_csu_init 249: 00008ce0 1656 FUNC GLOBAL DEFAULT 13 perform_calibration 000000: Version: 1 File: libc.so.6 Cnt: 1 ------------------------------------------------------------------------ I get same result for all the binaries. Then I did the same test in tests folder inside tslib folder from where tslib was installed. file ts_calibrate ts_calibrate: Bourne-Again shell script text executable I installed tslib from /usr/local/tslib(host pc) to mini2440 rootfs /usr/local/tslib. I also had to copy libdl.so.2 from cross compiler folder to mini2440 /usr/lib. I have a profile file with variables which is loaded by /etc/init.d/rcS. The variables are as follows: export LD_LIBRARY_PATH=/usr/local/tslib/lib #export QWS_MOUSE_PROTO=tslib:/dev/input/event0 export TSLIB_CALIBFILE=/etc/pointercal export TSLIB_CONFFILE=/usr/etc/ts.conf export TSLIB_CONSOLEDEVICE=none export TSLIB_FBDEVICE=/dev/fb0 export TSLIB_PLUGINDIR=/usr/local/tslib/lib/ts export TSLIB_TSDEVICE=/dev/event0 export TSLIB_TSEVENTTYPE=INPUT export QWS_DISPLAY=LinuxFB:mmWidth=800:mmHeight=480 export QTDIR=/usr/local/Qt I have not yet installed qt on mini2440. I am just running ts_calibrate from /usr/local/tslib/bin(mini2440) to check if that is working first. I am getting a new error now. ./ts_calibrate ts_open: no such file or directory. I did cat /dev/event0 to see if touch screen drivers are working. I get strange characters after I touch the screen. Is it correct? also while the kernel is booting I can see -------------------------------------------------------- Console: switching to colour frame buffer device 100x30 fb0: s3c2410fb frame buffer device backlight initialized mice: PS/2 mouse device common for all mice s3c2410 TouchScreen successfully loaded input: s3c2410 TouchScreen as /devices/virtual/input/input0 -------------------------------------------------------- I am struggling to get tslib working. If you dont mind can you please have a look at the attached logs and tell me what might be going wrong in my steps. thanks tama
You should google around for the usage of DESTDIR when you cross compile packages. Simply running "sudo make install" for a cross compiled package is a risk for your host. I thought you are aware of that. Run your "./ts_calibrate" with "strace" on your Mini2440 to see, what it tries to open and get an idea what's missing.
"I thought you are aware of that." Yikes ... doesn't --prefix /usr/local/tslib ensure you don't mess with your host? Or is --prefix /home/davef/install-arm/tslib a lot safer?
Using --prefix is sometimes run-time critical. If you define "--prefix /home/davef/install-arm/tslib" some packages compile in this path and try to load other components at run-time from this path and fail. But the autotools are DESTDIR aware. So, you can still define "--prefix /usr" for run-time and DESTDIR to "/home/davef/install-arm/tslib". This will result into an install path when you run "make install" to "/home/davef/install-arm/tslib/usr". This doesn't conflict with your host and at run-time the package still searches at "/usr" which is also correct (PTXdist uses this mechanism to let all packages install their results to "<your-platform>/packages/<package>/" for example).
Hi Juergen, Thanks for pointing to DESTDIR option. I tried running strace on mini2440, but i get a "-bin/sh: strace: not found" I even checked busybox 1.13 options using make menuconfig. Didnt find any option as strace. Does strace need to be installed separately? How to install this tool? My work place also have a mini2440 with 7inch screen. I tried to run ./ts_calibrate on that board. But I get the same error as ts_open not found. This board has the factory installed kernel and rootfs. Still ts_calibrate dosent work on this board. Then how can qtopia works with touch screen on this board. Any ideas as in how to resolve tslib. Thanks Tama
I do not use the original root filesystem coming with the board, nor I use their kernel. Sorry, I cannot help you with your software installation you have.
Hi Jurgen, Thanks for being patient and going through my threads. I managed to resolve the issue. It was my bad, it was because of wrong environment variable. Now ts_calibrate is working fine. Thanks Tama
hey tamamontum, could u please tell me what were the environmental variables that u passed to get ts_calibrate ??? Even I am getting the same error "ts_open: No such file or directory" I have set..... export TSLIB_TSDEVICE=/dev/input/ts0 export TSLIB_CALIBFILE=/etc/pointercal export TSLIB_CONFFILE=/usr/etc/ts.conf QWS_MOUSE_PROTO=tslib:/dev/input/ts0 Please help me.. Thanks Winston
I could get the touchscreen working following this link (I didn't do any of the QT stuff): http://linuxandstuff.blogspot.com/2012/05/mini6410-debian-with-touch-scr... The driver I used can be found here: ftp://ftp.friendlyarm.net/src/ And also, I found what I needed to export here: http://www.friendlyarm.net/forum/topic/4101 Good luck! -S
