Im trying to fuse SD card in order to install embedded Linux on my OK6410 board using IROM_fusing_tool.exe . however the software shows "fusing image done" but when i open up my card it shows no file. i have also used other SD cards and applications but no success. if anyone knows about it please help. Regards, warda
Problem fusing SD card
Simply you cannot see anything (files/folders) in your SD card. Because fusing means writing some boot codes into boot sector of your SD card. However, It will work well when you put SD card into SD cartridge on your board, set the on-board boot switches in an appropriate position, and boot your device up.
Hi i am trying to load wince OS in OK6410. completed fusing and inserted into board with appropriate switch selection. after that am not able to see anything in the DNW serial port. please help me to load wince os into my board
