Hello, I am trying to load the Wince Images using DNW. I am connecting my pc and mini6410 board thorgh serial and usb cable. then I RUN DNW tool. After connecting to serial port it shows me.. [COM1,115200bps][USB:x][ADDR:0x32000000] and bios menu. but if I go to transmit any file using USB it shows me "Can't open USB device" what should be the problem? Please guide me.
DNW usb not working.
HELLO ALL, I am still waiting for the Solution of this issue. Please someone guide me. THanks in Advance. Sumeet Thakre.
Hi, I am facing the same problem i am using micro2440 sdk board and not able to connect the board through DNW what is the reason can some body help
Sumeet, use the 6410's Superboot system. Program from an SD card. There are detailed directions here somewhere, or I can repeat them. Umer, you are on a 2440. Are you using the included serial cable? You can not use a plain serial cable. Plus it can take some fiddling about to get the correct USB port set on DNW.
Hello, Just solved the problem. The reason was: the driver for mini6410 was not installed in my PC. I had Installed [usb-downloaddr-setup_20090421]. and then DNW worked fine and displayed USB:OK. for more details search for (FriendlyARM Downloader Instructions)pdf. Sumeet Thakre.
Hi, I have a huge problem with OK6410 board not recognized by usb. I have intalled that usb_downloaddr (1) but when i plug usb in, it says sec s3c6410x test b/d. When i try to update firmware using that (2) link when windows XP detects the hardware it is not working. Even if I choose to search for the folder where I extracted that package. So dnw says whole time USB:x, so it's not working. Could someone please help me get through with this. (1) http://www.friendlyarm.net/dl.php?file=usb-downloaddr-setup_20090421.zip (2) http://www.friendlyarm.net/dl.php?file=usb-downloaddr_20090421.zip
hello. i gave Sumeet Thakre's solution but is not working. actually i copied SECBULK.inf file into C:\Windows\inf and SECBULK.sys into C:\Windows\System32\drivers (is it correct ?) and it "can't open USB device" yet by dnw. i have tested on Windows7 32bit with mini6410. plz help me... it is very immediate.
oh, problem fixed... while the blue cable "and" mini USB cable are connected, the SD Card must be into mini6410, and CheckOneButton=Yes in FriendlyARM.ini now i can monitor everything through dnw
I have formatted NAND flash. i am using ok6410 ARM11 board and not able to connect the board through DNW in SDboot or NOR layout what is the reason can some body help me
Just to someone that my wonder why his device is not recognized after installing the USB Drivers. In order to be recognized you have to switch S2 to NOR and than it will recognize it. Procedure Turn off device (S1 to OFF) Switch S2 to NOR Turn on device (S1 to ON) Connect thru USB B connector After installing the drivers you can switch back to NAND (S2 to NAND)
I am using win 7...i got the bootloader and fuse it into my 1gb pendrive,inserted it into the board...i connected the mini usb cable and started DNW now i power on the board....i show me [COM1,115200bps][USB:x][ADDR:0x32000000]..now how com i know the com the baud..i don't know but i got it...how could i define the usb?........pls help...i even tried pressing reset and powering the board on.
jub16, firstly define your problem clearly in order to get correct answer. Go to "downloads" section of this website and download manual. Start reading slowly and you will find all your answers. Don't panic, read slowly and follow one by one.
@BaHko i have tried your procedure but unfortunately,the usb driver is still not recognized and i am currently using win7 32-bit with mini 2440. kindly give your suggestions.
@janani, you must conduct step by step as following: 1. plug cables ( 2 cables)and not open switch source mini2440 2. play dnw.exe 3. install FriendlyARM_USB-Download-Driver.exe 4. configuration--> option-->11520 and your com number (find in your computer) --> ok 5. serial port--> connect 5. now, open source switch kit . note : if here hasn't menu list NOR Flash, please toogle cable COM to COM which connect to your kit. Goodluck
I have the same problem. I follow all the steps you provided but there's still no display of the menu list on DNW.
GUys! I am using windows xp professional in vm workstation. Virtual xp machine is not able to detect my mini 2440 even though i installed USB driver. Pleas help
@tn88test I have the same problem. I follow all the steps provided but there's still no display of the menu list on DNW. help me if u already solved the problem
