I have a small project. I wish to port approximately 15 lines of C++ code to Keil MDK-ARM to run on Mini2440. Code needs to be compiled into .BIN file and run at bootup. Problem is I don't know how to setup Keil project on mini2440. Should only take <15mins. Will pay $125 + possible larger project. Send me email to mcjonster@yahoo.com
Need ARM consultant
Hi, I am available to help if you still need it. I have been working on ARM embedded systems for the last 10 years. Cheers, Frank Parrish
Hi Frank, Even I am looking for some support on porting Keil on MINI2440, could you please send me your contact details to sriks.rao@gmail.com Thanks Sriks
Hi Frank I have some problems using windows Ce on mini2440 can you help me ? pls contact me at : hadiamouhashemi@gmail.com Best Regards
Hi Hadi, Could you tell what problems you had on Win CE? I have been using the Mini2440 board for four months andhave found it to be pretty useful. Maybe I could help. Cheers! micromeister
Hi Frank Parrish, I have Issue with NAND flash if u can help me then I will elaborate the issue Regards,
