root file system failure.
hansoo
Hi, this is the failuer situation what i got right now which compiled
2.6.32.2 kernel(linux-2.6.32.2-mini2440_20110413.tgz) and provided your
site. i just tried replace kernel only without change the yaffs file system
that provided. once i boot the kernel it always shows me right by that
messages bellow. any ideas would be nice and thanks in advance.
Best Regards.
hansoo
Enter your selection: b
Copy linux kernel from 0x00050000 to 0x30008000, size = 0x00200000 ... done
zImage magic = 0x016f2818
Setup linux parameters at 0x30000100
linux command line is: "noinitrd root=/dev/mtdblock2 init=/linuxrc
console=ttySAC0"
MACH_TYPE = 1999
NOW, Booting Linux......
Uncompressing
done, booting the kernel.
Linux version 2.6.32.2-FriendlyARM (iryna7@DEV140-26) (gcc version 4.2.4)
#9 Fri Feb 17 01:14:52 KST 2012
NetWinder Floating Point Emulator V0.97 (double precision)
yaffs Feb 16 2012 14:00:35 Installing.
loop: module loaded
s3c24xx-nand s3c2440-nand: Tacls=3, 29ns Twrph0=7 69ns, Twrph1=3 29ns
s3c24xx-nand s3c2440-nand: NAND soft ECC
NAND device: Manufacturer ID: 0xec, Chip ID: 0x76 (Samsung NAND 64MiB 3,3V
8-bit)
Scanning device for bad blocks
Bad eraseblock 1394 at 0x0000015c8000
Creating 4 MTD partitions on "NAND 64MiB 3,3V 8-bit":
0x000000000000-0x000000040000 : "supervivi"
0x000000040000-0x0000000a0000 : "param"
0x000000060000-0x0000005c0000 : "kernel"
0x000000560000-0x000004000000 : "root"
dm9000 Ethernet Driver, V1.31
eth0: dm9000e at c4808300,c480c304 IRQ 51 MAC: 08:90:90:90:90:90 (chip)
s3c2410-rtc s3c2410-rtc: setting system clock to 2165-01-04 23:32:08 UTC
(1859043832)
yaffs: dev is 32505858 name is "mtdblock2"
yaffs: passed flags ""
yaffs: Attempting MTD mount on 31.2, "mtdblock2"
yaffs_read_super: isCheckpointed 0
VFS: Mounted root (yaffs filesystem) on device 31:2.
Freeing init memory: 148K
Failed to execute /linuxrc.  Attempting defaults...
Kernel panic - not syncing: No init found.  Try passing init= option to
kernel.
Backtrace:
[<c003223c>] (dump_backtrace+0x0/0x114) from [<c00326c8>]
(dump_stack+0x18/0x1c)
 r6:c03c13dc r5:c001ea00 r4:c03c0e14
[<c00326b0>] (dump_stack+0x0/0x1c) from [<c0045a80>] (panic+0x4c/0x13c)
[<c0045a34>] (panic+0x0/0x13c) from [<c002d5bc>] (init_post+0xd0/0x10c)
 r3:c033a55c r2:00000000 r1:c0464980 r0:c033a564
[<c002d4ec>] (init_post+0x0/0x10c) from [<c0008814>]
(kernel_init+0xf0/0x120)
 r4:c03c0e18
[<c0008724>] (kernel_init+0x0/0x120) from [<c0048a60>] (do_exit+0x0/0x634)
 r6:00000000 r5:00000000 r4:00000000
Are you using DNW for download?
hansoo
right, DNW is the only download and debuging terminal.
"replace kernel only . . ." with which kernel?
How did you compile the kernel, ie which cross-toolchain?
hansoo
replace(downloaded) to linux-2.6.32.2-mini2440_20110413.tgz kerenl which is
compiled cross-tool belows
#arm-linux-gcc -v
Using built-in specs.
Target: arm-linux
Configured with: ../configure --target=arm-linux --disable-shared
--prefix=/usr/local
--with-headers=/home/gerg/src/gnu/arm-linux/linux-2.6.25/include
--with-gnu-as --with-gnu-ld --enable-multilib
Thread model: posix
gcc version 4.2.4
Sorry, I do not have a clear picture of what you are trying to do?
Sounds to me like you have compiled the kernel, with some new options AND
are still using the root filesystem that was associated with that kernel.
In that case I do not know what has gone wrong.
Be aware that you can get into difficulties mixing kernels and root
filesystems when they have been built using different toolchains.
hansoo
okay, this is compiled with few options(mostly removed) for the test
matters.
anyhow, thanks a lot davef. i have to digging more about the kernel and
root file systems, i guess.
Search for this phrase on the forum:
<Failed to execute /linuxrc>
And try compiling the kernel without making any changes and see if that
works.
And then look for:
<Kernel panic - not syncing: No init found.  Try passing init= option to
kernel.>
Good luck!
Juergen Beisert
This sounds like your kernel mounts an empty partition.
You have *4* partitions and you using "root=/dev/mtdblock2". Should be
"mtdblock3" I guess.
nitheesh Nair
kernel.
Backtrace:
nitheesh Nair
dear sir
i have compiled a readly available code from the web, but it give me such
type of error when i try to load into my mini2440.
i m using "arch=arm-cross-compile" to compile the linux
please help me out
thanking you
with best regards
Nair Nitheesh
Perhaps tell us where you got this "readly available code". Which
touchscreen on the mini2440?  Maybe, tell us which tutorial you are
following.
"arch=arm-cross-compile" is unfamiliar to me.
Then which host distribution you are using and which arm cross compile
toolchain.
Juergen Beisert
> kernel.
Seems you root file system is empty. "Warning: unable to open an initial
console." means the kernel cannot find a '/dev/console' device node.
lgx
I think, First of all, try Juergen Beisert's suggestion, from ur
partition's info,ur rootfs is in mtdblock3.
I have the same problem(2.6.32 and mini2440) and work on it.
Raja
hi everyone,
my rootfs file is not loading on mini2440 board.. showing error
i downloaded supervivi, zImage and rootfs file from friendlyarm website...
what may be problem..
thanks in advance....
plz help me out
Search for "No init found"
Which size flash are you using?
Pramod
Attachment: Screenshot-1.png (191.76 KB)
I am using s3c2440
i ported
1) supervivi-128M
2) zImage_gpio_wifi
3) rootfs_qtopia_qt4.img
i am getting some errors when booting the board, kindly see the screen
shot.
kernel.
Backtrace:
