Hello! Anyone tried to port .NET MF to mini2440? Do I need to write my own HAL & PAL drivers before porting? .NET MF should support ARM9 (S3C2440 is ARM920 based)! Any help is appreciated, [Beer]
Porting .NET Micro Framework 4.0 to mini2440
This boards are supported by .NET MF http://informatix.miloush.net/microframework/HardwareComparisonModules.aspx
Hi, I would like to suggest you that TI Stellaris, a ARM Cortex M3 32-bit MCU. It can give best price with performance for .NET Micro Framework. We had successfully port Microsoft .NET Micro Framework to TI Stellaris MCU. Please refer to following video link for TI Stellaris LM3S9B96 runs Microsoft .NET Micro Framework live demo. http://www.youtube.com/watch?v=nO_IWpr-vJU If you are interested, please conatct us. Stan Chen Golden IC technology Co., Ltd. Stan@golden-IC.com http://www.Golden-IC.com/page1.php Tel: +886-2-89920883 Ext.101
Hi, Actually I am looking for the same issue, I have the same board and I am trying to run NETMF over it. if there is anyone who make successfully I would appreciate sharing information Thanks in advanced ... MR
Hi, I ordered a mini2440, as it seems the ideal and cheap paltform for some hobby projects. Any news on the porting process?
Eagerly waiting for any news about the porting .net microframework on Mini2440? Or show us a starting point to go into painful process of porting it. Is there anyone who has tried it. This is a brilliant board which is affordable with touch LCD etc.... I would like to hear from anyone out there who can enlighten us. Regards
I would like to attempt the port to the Mini2440 board, but for starters the processor isn't selectable in the porting wizard. Should I selected the 9261 atmel part or is there a better selection I should make?
Hi, I’m interested about porting Micro2440SDK board. I tried to port using 9261 atmel, but after a while I decided that it’s easier to start from scratch using the Template project. I created project called “S3C2440 .NET Micro Framework port” in CodePlex. You can find it from http://s3c2440mfport.codeplex.com/. Do you want to join the project so that we can develop the port together? I have managed to get NativeSample running using U-boot bootloader. Here’s the output from NativeSample: http://s3c2440mfport.codeplex.com/discussions/256331
Hi, You can now download first version of TinyCLR from http://s3c2440mfport.codeplex.com/releases/view/68512. Deploying a managed application is little tricky, because debugger has some problems. Here is a video how it can be done: http://www.youtube.com/watch?v=zIUQpe-Sp6Y
Hi Matti, I've just seen your post and after my holiday in October I'll folow your video and try to get the CLR working. I'll have a play and let you know what my thoughts are on getting a full port up and going. It'd be a very worthwhile project and would help a LOT of people. I'm currently getting to grips with C++ as C# is my programming language of choice at the moment. I'll update you later in October.. Regards, Dan
Hi Matti, I've finally got around to fixing my pc (blown psu, graphics card and dvd drive :( ). I've got the Micro Framework installed (4.2) and compiled PKStudio. I get some errors when trying to build TinyCLR, most of which are located in the file "Microsoft.SPOT.Build.Common.Targets". These errors are complaints about missing files that do exist!?! Have you tried building the CLR with version 4.2? I really want to get the CLR built so I can start to modify drivers etc and then to finally write drivers for devices that aren't currently supported. Do you have any pointers or ideas on where to start? Thanks, Dan
I also get an error after copying your solution files to the relevant folder so that I can open the solution with Solution Wizard. The following settings are displayed and when I click next I get "Invalid data has been entered"; Processor/OS: S3C2440 (cannot change as greyed out) Debugger Port: empty and unchangeable Memory Profile: Medium RAM Base: 0x30000000 RAM Size: 0x04000000 Flash Base: 0x08000000 Flash Size: 0x10000000 System Clock (Hz): 405000000 Slow Clock (Hz): 64 Any info or pointers will be much appreciated. Regards, Dan
Update: I've managed to get most of it to build, but it all falls over when processing the scatterfile. I didn't have an mdk version of the file and it seems that the RVDS one isn't going to work with my compiler. If anyone has a scatterfile for the S3C2440 for MDK, using the ARM C/C++ Compiler, 4.1 [Build 481] [Standard], and could send it to me that would be much appreciated... Other than that I'll have to wait until I find time to get the TinyCLR to finish compiling. Dan
