Running Script on Startup
ekent
I am wanting to run a simple script on startup of my mini 2440 board to
connect a wifi module and turn on the video camera.  The commands are:
start-wifi wep name pass
./start_uvc.sh
I looked at general linux forums and they tell me to add entries to files
that the mini 2440 does not have, how can I get these commands to run
automatically on the system startup?
Have you got a /etc/init.d/rcS ?
What root filesystem are you using?
ekent
I'm running linux 2.6.32 and yes I do have /etc/init.d/rcS but I dropped
the script path /usr/sbin/startup.sh into it and it did not run
linux 2.6.32 is the kernel.  The root filesystem is ?
I think you just modify the rcS file. Have a look at it, try commenting out
a line (perhaps a line with echo xyz and see if something breaks.
What tells the your kernel to go looking in /usr/sbin for a startup.sh?
ekent
Sorry, kind of new to the linux command line stuff.  Root filesystem?
And I put a link to the startup.sh script in the /usr/sbin directory inside
the rcS file you mentioned but it did not work
Root filesystem.  All your directories, default files before you start
putting in the stuff you want.
If you are using the FriendlyArm distro it is a YAFFS2 filesystem with a
lot Qtopia applications.  How things get initialised can vary between
different root filesystems.
Busybox looks for certain files during the init process.
Did you try to change something in the rcS file to give you some confidence
that you were changing things in the right place?  Then just add your
script command lines to this file.
Maybe, if you copy and pasted the contents of your rcS file it might help.
