hi, i need some help, i have arm mini 6410 and i write this code it's run perfect with emulator, but it's not work with mini 6410 Error: is not enough space on the disk if is not enough space on the disk when how i can run this code? please help me, best regards http://ressim.net/b/out.php/i5486930_untitled-1-jpg my code: private void button1_Click(object sender, EventArgs e) { SqlCeConnection baglanti = new SqlCeConnection("Data Source=" + (System.IO.Path.GetDirectoryName(System.Reflection.Assembly.GetExecutingAssembly ().GetName().CodeBase)) + "\\Northwind.sdf; Persist Security Info=False;"); SqlCeCommand cmd = new SqlCeCommand("select CategoryName from Categories", baglanti); baglanti.Open(); SqlCeDataReader dr = cmd.ExecuteReader(); while (dr.Read()) { textBox1.Text += dr.GetString(0); } } http://ressim.net/b/out.php/i5486930_untitled-1-jpg
Mini6410 error MSsqlCE
i solved the problem, in winCE My Device-->(right click)properties-->memory this: http://c1202.hizliresim.com/u/h/2r2xk.jpg and i debug my code and i take this error: http://img845.imageshack.us/img845/5945/41707511.jpg why i take this error?
