Hi im trying to compile the examples (who comes on the cd ) the i2c example but i having this mistake: /tmp/ccsaJC3B.o: In function `read_from_eeprom': eeprog.c:(.text+0x144): undefined reference to `eeprom_read_byte' /tmp/ccsaJC3B.o: In function `write_to_eeprom': eeprog.c:(.text+0x2e4): undefined reference to `eeprom_write_byte' /tmp/ccsaJC3B.o: In function `main': eeprog.c:(.text+0x424): undefined reference to `eeprom_open' eeprog.c:(.text+0x4d8): undefined reference to `eeprom_close' collect2: ld returned 1 exit status i have compile succefull other examples like hello or comtest but with this one i dont know what im doing bad, im trying to compile it with this command line: arm-linux-gcc -o eeprog eeprog.c I hope someone can giveme and hand with this. Thanks!
compile i2 example
What #include files does eeprog.c have in it? Are they in your project? Can you find, for example: eeprom_read_byte anywhere?
Try this: arm-none-linux-gnueabi-gcc -Wall -O2 -c -o eeprog.o eeprog.c arm-none-linux-gnueabi-gcc -Wall -O2 -c -o 24cXX.o 24cXX.c arm-none-linux-gnueabi-gcc -Wall -O2 -o i2c eeprog.o 24cXX.o Best regards, Łukasz Skalski www.lukasz-skalski.com
Thanks for the help, i found two ways to compile it 1. add this to eeprog.c: #include "24cXX.c" 2. compile with this command line: arm-linux-gcc -o eeprog eeprog.c 24cXX.c thanks for the help!
Hi actually im reading the eeprom, but now im trying to find the way to read another page from the eeprom, im still using the code sample, and im reading the first 256 bytes i hope someone can help me , thanks!
hi, i solve my problem it was very easy
("/dev/i2c/0", 0x50
for change page i only change 50 for 51 or the page that i need to read
