Segmentation fault with Mini2440
alef
I would like to use home-made programs on my Mini2440, so I first
installed the cross-compile toolchain provided by FriendlyArm
(arm-gcc-4.3.2).
I simply compiled a simple program with this command :
./arm-none-linux-gnueabi-gcc ./test.c -o test
But when I run it on my Mini2440, I get a segmentation fault !
I don't understand why ...
I tried agin with these flags :
-msoft-float -D__GCC_FLOAT_NOT_NEEDED -march=armv4 -mtune=arm920t
No seg fault occurs but I've got a different error....
Do you think I do the right things ?
Thanks !
themadmax
Try file command on host machine for verify binary type.
If you use FTP to send file to your board force binray transfer
alef
Thanks ! It works!
David
I have also met this problem but unfortunately I cannot understand the
answer. :-s
How can I do that you are suggested above?
Thank you, David
