Hi there, I recently just purchased a Mini2440+3.5" LCD pack and im in need of some advice as to where i should start off from. At the moment i would like to know how to develop applications and deploy them to the Mini2440. So far i've installed the Qt SDK from Trolltech onto my Vista system, but im confused cos there's also a version for embedded linux...? I know there's a lot of info out there, but it'd be nice to have a clear direction. Any help would be great. Kind regards, Ade
Beginner Starting Point
I think you have much to learn then, Learn about linux, using a cross-compiler and embedded linux. The difference in Qt for your computer and embedded Qt is just how the qt lowlevel api writes the pixels to the screen and access the hardware. Qtopia/Qt extended is just Qt on the linux framebuffer device. Below there all my mini2440 related links: http://code.google.com/p/mini2440/ http://wiki.linuxmce.org/index.php/Mini2440 http://repo.or.cz/w/linux-2.6/mini2440.git http://devbored.com/wiki/index.php?title=Main_Page http://bliterness.blogspot.com/ http://code.google.com/p/qq2440-linux/ http://blog.leshak.ru/english/ http://labs.kernelconcepts.de/Publications/Micro24401 And my linux links collection: http://linuxworld.eigenstart.nl (I recommend that you download ubuntu 9.04 and try to install it on a machine to experiment with linux in general) Regards, Jerry
Hi, Am attempted to download the WinCE image after that i lost the supervivi boot loader menu and OS also. Now DNW window i did not get USB connection (USB not reorganized) only have serial only. Now i power on LED not bilging only Power LED only glowing please help me how to get supervii menu/ how to retrieve USB connection/OS thanks in advance syed zaiath
Can you boot in NOR mode and do you see a menu in DNW? Have you tried the steps from the Linux Download Manual: http://www.friendlyarm.net/dl.php?file=linux_download.pdf
Hi, Am tried both NOR and NAND flash in PC hyperterminal and DNW window also also connected rs232 and USB cable boot menu not apeare, USB not detected. Am not get any download menu, how can i burn other image?? I hope supervivi boot loader erased. How can I re-burn the image (menu not coming) Can i get link for supervivi image download, Any possible to download/burn image by using HJAG parallel cable. What is the ROM address of supervivi. How can i burn image from JTAG. Kindly Help me How to give the life on board thanks & regards zaiath
Hello, The images are on the Download site and a JTAGing guide can be found here: http://andahammer.com/faq Regards Tom
