Hello I have a problem to enter the system interface. I can not find the solution for my device Mini2440 with 7 "screen Typing "startx" I get the following error: hostname: Unknown host xauth: (argv):1: bad display name "mini2440:0" in "list" command xauth: (stdin):1: bad display name "mini2440:0" in "add" command X: warning; process set to priority -1 instead of requested priority 0 X.Org X Server 1.4.2 Release Date: 11 June 2008 X Protocol Version 11, Revision 0 Build Operating System: Linux Debian (xorg-server 2:1.4.2-10.lenny4) Current Operating System: Linux mini2440 2.6.32-rc8 #1 Tue Jan 31 20:41:50 CST 2012 armv4tl Build Date: 03 August 2011 09:52:37PM Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. Module Loader present Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. (==) Log file: "/var/log/Xorg.0.log", Time: Mon Feb 6 17:16:36 2012 (==) Using config file: "/etc/X11/xorg.conf" Data incomplete in file /etc/X11/xorg.conf Undefined Screen "Screen" referenced by ServerLayout "XFree86 Configured". (EE) Problem parsing the config file (EE) Error parsing the config file Fatal server error: no screens found giving up. xinit: Connection reset by peer (errno 104): unable to connect to X server xinit: No such process (errno 3): Server error. xauth: (argv):1: bad display name "mini2440:0" in "remove" command I have reviewed all possible solutions but cannot find the solution. I hope you can help me. I appreciate you very much for your help, thanks
