cannot find evtest-1.25.tar.bz2
luc
I am trying to build pengutronix .
It stops with an error it the fioe  evtest-1.25.tar.bz2 cannot be resolved
from freedesktop.org.
I googled it and downloaded the file from somewhere else.
Now it stops with the error Wrong md5sum for 'evtest'.
Can somebody share the file please.
Luc.
Juergen Beisert
Maybe they re-pack the archive. You can add the new MD5 sum after the
existing one. Copy the file 'evtest.make' from the rules/ directory of your
PTXdist installation (usually '/usr/local/lib/ptxdist-<version>') into your
local project's rules/ directory. Then edit this local file and extend the
EVTEST_MD5 line with your new MD5 sum. After that it should build. If you
know a new location where to download this archive I would be happy if you
could send me the URL.
luc
Thanks Juergen !
It works !
Here is the URL :
http://pkgs.fedoraproject.org/repo/pkgs/evtest/evtest-1.25.tar.bz2/f0c05...
praveen
hi,
here is the url with download which is working with no md5 error..i found
it after extensive googling(3 hours.:(.)....hope this helps others...:)
http://enialis.net/~jrd/salix/evtest/1.25-i486-1cp/
Juergen Beisert
Thanks, fixed for the next PTXdist release.
