hi working on mini2440 it appears me this mistake: Warning: at net/sched/sch_generic.c: 261 dev_watchdog+0x260 netdev watchgod: eth0 (cs8900) : transmit queue 0 time out has some else have this kind of message? any ideas how can i solved it looking around i found this: http://blog.csdn.net/lobbve/article/details/4061254 but the step #3 itsnt very clear for me # Make menuconfig Enter the configuration menu to add drivers to the kernel it doesnt say what drivers do i have to add i hope some one can help me Thanks!
wach dog error?
As I mentioned in your other post how can the mini2440 report a cs8900 error, unless the dm9000 driver has been hacked around? Also that article seems to be talking about the smdk2410 which maybe does use the Cirrus Logic ethernet controller. Which kernel are you trying to configure? Have you got the default mini2440 kernel configuration for that kernel?
hi im trying to configure : config_gt2440_h43 i have compile that kernel to add gpio and change the boot image, but the other setting are by default , exactly how it came on the cd. on this mini i havent try to change mac address yet. Thanks for the fast answer and sorry for my bad english
Which kernel are you trying to configure? If you look in the kernel source what code can you find for the ethernet chip?
the files that im working on its: from cd i take the package: linux-2.6.32.2-gt2440-20101104 And its has to many files, when i compiled it i only made changes doing this steps: cd linux-2.6.32.2 cp config_mini2440_t35 .config make menuconfig on the menu it opens i made the changes make zimage. but on this case im making changes on the files that describes this links: http://hi.baidu.com/operationsystem/blog/item/5ab9a37f8f3635300dd7da0e.html i havent made anything diferents that describes there. what its the file about what you are talking about? forgive my ignorance thanks!
That article refers to a very old Linux kernel, the wrong ethernet controller chip and a different development board. If you compile the kernel WITHOUT modification does this error message appear? Maybe, briefly describe what you are trying to do, other than get the GPIO to work. Maybe you have ticked some wrong boxes in menuconfig. You could do a "diff" or using MELD see what the differences are between your configuration and the default supplied configuration. Another question about that package you are using, are you sure that is for your mini2440? First you say: config_gt2440_h43 and now config_mini2440_t35 .config I have no idea what "gt2440" refers. Also, first you are talking about the h43 touchscreen then the t35 touchscreen. These would be different configuration files. Which touchscreen do you have? And lastly, have you ever managed to compile a default kernel and get it to work on your mini2440?
Hi this mistake appearsme even with the kernel that comes with the cd, i have an application running on mini2440, after 2 days running it comes slow, until it get blocks and on the console appearsme that menssage, first i tought that it was fail of my application, but then i reebot the device, and without execute my application, the mini2440 was slow. and continues with this message: Warning: at net/sched/sch_generic.c: 261 dev_watchdog+0x260 netdev watchgod: eth0 (cs8900) : transmit queue 0 time out im working on h43 mini, what i copy above was from a tutorial that i found, and works for me, obviously i change _t35 for _h43 then i have a question the actual kernel has solve that problem?, could be my default kernel (who cames on the cd ) have came with something different? And about your last question: "have you ever managed to compile a default kernel and get it to work on your mini2440?" yes i have do it but making the steps that i copy you above " cd linux-2.6.32.2 cp config_mini2440_t35 .config make menuconfig make zimage." then i cames a menu and i have select what i need,(gpio) but i have never change the codes of the kernel manually. i hope to be clear about what i have done until now. thanks for all your help!
hi the problem its very similar, i have to application one qt application and web server, when i have been problems on qt the webserver hasnt been affected but this time both of them gets slow. they start well and after one or 2 days they gets slows, until the web server stops to work, and even the ftp service (what it came install with mini) after they get slow i turn off the mini2440 and i only turn on the web server, and i note that its speed was too slow, it wasnt working as fast as when i put it 3 days ago. as far as i know if i reset the mini2440 the ram memory should be clear, and the web server should work normal. but i doesnt, i put a command line to clear the memory (right nown i dont remeber it) and the web server works well for 2 or 3 minutes but after that i came very slow. for now i dont know what to think, if is it the memory ran why the web server doesnt return to the normally after i reset the mini2440, thanks for all your help. could you giveme a link where i can download another kernel for h43?e maybe my default kernel cames wrong or what else could be? thanks!
How about trying the "free" command and watch what happens to your memory over time? What are you using for a web server? Rebooting the mini2440 should clear any memory. Where are you running the kernel and root filesystem from? NAND/SD card/NFS
the kernel, filesystem and webserver are running on mini2440, the qt application and the www file are on /sdcard my web server its cherokee
hi , i made this test: i have two mini 2440 making different test to try to find the solution for this, one of them was very very slow do i decided to format it and mount again my web server (i didn't mount the qt application), after that, i ran it i noted that it was slow as before i formated my mini2440, after that i formated the sdcard (who contains the files of the web server) and later past again my files to the sdcard. turn on again my mini2400 and checking my webserver i saw that i continued slow. the second mini2440, on that moment was faster ( i had started another test on him for not to much time ago on him ) i suppose that in a time it will come slow. the interesting thing was that i toke the sdcard from my second mini, and put it on my first mini2440 i checked the web server and its was ok. now im starting to think that it is a problem on the sdcards, but what could be? i hope to be clear on what i tested (sorry if my english its not good ) i hope that with this information you can giveme some ideas, thanks for the help!
both of them are panasonic, but the fist mini had 2 gb and the second had 4gb. but in a previous test, the sdcard of 4gb has fail too. even in one cause it changes all files that its had to ONLY READ FILED and i couldn't drop or modified the files that it contained
HI i have found the reason of my problem, it was diferents things, one of them was the sdcard that i was using, its bad , and the second, the system gets out of memory ran, for my qt application. thanks for all your help. the idea to see the memory ran was very useful. im going to fix my qt application, but i would like see if there is a possibility to install memory swap on mini2440 (just to enforce the system) my SO its qtopia, any help could be great for me. Thanks again!
