Hi During install of the OSELAS.Toolchain-2011.11.1 zlib-1.2.5 cannot be found. seems there is a 1.2.6 version. How to resolve this problem? Thanks Luc -------------------------- target: zlib-1.2.5.tar.bz2 -------------------------- --2012-02-01 19:37:37-- http://zlib.net/zlib-1.2.5.tar.bz2 Resolving zlib.net... 69.73.181.135 Connecting to zlib.net|69.73.181.135|:80... connected. HTTP request sent, awaiting response... 404 Not Found 2012-02-01 19:37:37 ERROR 404: Not Found. --2012-02-01 19:37:37-- http://www.pengutronix.de/software/ptxdist/temporary-src/zlib-1.2.5.tar.bz2 Resolving www.pengutronix.de... 78.47.139.85, 2a01:4f8:121:2:5054:ff:feaf:fc62 Connecting to www.pengutronix.de|78.47.139.85|:80... connected. HTTP request sent, awaiting response... 404 Not Found 2012-02-01 19:37:37 ERROR 404: Not Found. Could not download packet URL: http://zlib.net/zlib-1.2.5.tar.bz2 make: *** [/home/luc/Local/OSELAS.Toolchain-2011.11.1/src/zlib-1.2.5.tar.bz2] Error 1 luc@luc-VirtualBox:~/Local/OSELAS.Toolchain-2011.11.1$
error building OSELAS.Toolchain-2011.11.1
Hi again, I have changed this in .../rules/host-zlib.make HOST_ZLIB_VERSION := 1.2.6 HOST_ZLIB_MD5 := dc2cfa0d2313ca77224b4d932b2911e9 at this moment its building ... Maybe this is usefull for somebody Luc
Or find the wanted version and drop it into the recommended place for all source code, ie /home/ptxdist/all_src and set that up in "ptxdist setup" -> sources There might be a problem using a newer version. You could search here this issue has been discussed. http://blog.gmane.org/gmane.comp.embedded.ptxdist.oselas.community
Thanks Dave, it is a better idea to drop the missing source code into the /src directory because there are some other packages missing while compiling BSP Luc
Luc, you can run a "ptxdist get" prior the build. This will start to download all packages at onces. If it fails at some package download it manually from another location and re-run the "ptxdist get" until all archives are available. As Dave suggested you should setup one location for all archives. This will save time, as the download occures only once per archive. When all archives are present, the "ptxdist go" should work as expected. Changing the URL in the rule files is also a good idea. When changing the version of the package at the same time you might face problems with the new release. Changing the version is more a developer feature and requires tests after it, if there are no negative side effects. But if you are sure the new version does not break other packages this change is welcome at our ptxdist mailing list to improve PTXdist itself.
