I would like to directly connect these two items, but they won't work together, with a direct cross-over connection. I have enabled eth0 as it was broken in Ubuntu 10.04LTS on this netbook model D255E, by using this HowTo: http://www.cnx-software.com/2011/08/21/installing-ubuntu-10-04-lts-in-ac... The netbook with now talk to a Desktop Dell running Linux, two mini2440s will talk to each other and the mini2440 will talk to the Dell . . . all using a cross-over cable. But the netbook will NOT talk to the mini2440 or the other way around. If I connect them to my local network, or interpose a switching or non-switching hub or a USB to ethernet adapter they will talk to each other. The mini2440 appears not to receive ARP requests from the netbook, by looking at /proc/interrupts (on the mini2440) and doing arp -n (on the netbook) no HW MAC address for the mini2440 is seen. Before I have to learn how to debug the driver for the DM9000 I was hoping this problem might sound familiar to someone. Appreciate any comments, Thanks, Dave
Acer Aspire ONE running Linux and mini2440
All I know is, the DM9000 does not support auto detection/swiching of TX/RX. I will check your scenario this evening
My test environment: A DELL D610 laptop, regular network cable and a Mini2440. My laptop comes with an auto RX/TX detection/switch feature. I have connected both systems via this network cable, configured the ethernet interfaces at both sides to the same network and was able to ping my Laptop from the Mini2440 (inside Barebox and kernel) and vice versa when the kernel was up and running at the Mini2440. Also TFTP/NFSroot has worked with this kind of connection. So sorry, but I have no idea why this config does not work at your side.
Juergen, Correct on DM9000 capabilities. I relented and actually made some measurements and discovered that the RX levels at the mini2440 are about 1/2 the value when driven by the Acer Aspire ONE as compared with the other machines. Tells me that I need to talk to someone as Acer. It uses the Atheros AR8152 chip. Thank you for taking the time to make some tests at your end. Dave
Just an idea about the half levels: isn't ethernet a current driven interface? So, maybe the impedance of the cable, the Mini2440 and/or your laptop do not match the ethernet spec.
Discussed this with a ethernet interface specialist and yes just measuring the voltage levels only gives me an indication that something is different between the various machines. IE the netbook running a special driver to enable eth0 using Ubuntu may not be setting the TX levels correctly. I will check how well it works using Windows 7.
