firstly attach usb device TL-WN321G in mini2440 but I did not make any set up... What settings should I do first before. wireless,wpa exp.. and how usb 1-1: new full speed USB device using s3c2410-ohci and address 3 usb 1-1: New USB device found, idVendor=148f, idProduct=2573 usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 usb 1-1: Product: 54M.USB....... usb 1-1: Manufacturer: Ralink usb 1-1: SerialNumber: 12345 usb 1-1: configuration #1 chosen from 1 choice [root@miniarm /]#iwconfig -/bin/sh: iwconfig: not found
wireless iwconfig
ok.. how to download wireless tools . I don't understand lib,module... I make only copy scan-wifi,start-wifi,wpa-supplicant and # scan-wifi modprobe: chdir(/lib/modules): No such file or directory modprobe: chdir(/lib/modules): No such file or directory modprobe: chdir(/lib/modules): No such file or directory modprobe: chdir(/lib/modules): No such file or directory ifconfig: SIOCGIFFLAGS: No such device 0 Access Point Found I get this. How do I solve this problem
I compiled wireless tool-29 as down ARCH=arm CC=arm-linux-gcc-4.3.2 make ARCH=arm CC=arm-linux-gcc-4.3.2 make install and iwconfig iwlist iwpriv iwspy iwgetid iwevent ifrename files copy in /usr/sbin/ and libiw.so.29 iwlib.so files copy in /lib and run iwconfig,iwlist I get eror [root@mini2440 /]# iwconfig /usr/sbin/iwconfig: line 2: syntax error: unexpected word (expecting ")") [root@mini2440 /]# iwlist /usr/sbin/iwlist: line 1: syntax error: unexpected "("
kernel linux-2.6.32.2 I built root file system with buysbox 'ARCH=arm CC=arm-linux-gcc-4.3.2 make oldconfig' rsC in #! /bin/sh PATH=/sbin:/bin:/usr/sbin:/usr/bin runlevel=S prevlevel=N umask 022 export PATH runlevel prevlevel # Trap CTRL-C &c only in this shell so we can interrupt subprocesses. trap ":" INT QUIT TSTP hostname BYROKON # mounting file system specified in /etc/fstab mount -n -t proc none /proc mount -n -t sysfs none /sys mount -n -t usbfs none /proc/bus/usb mount -t ramfs none /dev mkdir -p /dev/pts /dev/shm /proc/sys/kernel echo /sbin/mdev > /proc/sys/kernel/hotplug mdev -s mount -n -t devpts none /dev/pts -o mode=0622 mount -n -t tmpfs tmpfs /dev/shm mount -n -t ramfs none /tmp mount -n -t ramfs none /var mkdir -p /var/empty /var/log /var/lock /var/run /var/tmp hwclock -s # start logging utility services echo -n > /etc/syslog.conf syslogd # set host and config loopback interface ifconfig lo 127.0.0.1 /etc/init.d/ifconfig-eth0 # prepare qt embedded library source /etc/profile if [ -r "/etc/pointercal" ] then /usr/project/deneme -qws else /usr/local/tslib/bin/ts_calibrate sleep 3 /usr/project/deneme -qws fi in lib list -rwxr-xr-x 1 root root 27096 Jan 1 00:11 iwlib.so -rwxr-xr-x 1 root root 148622 Nov 18 2008 ld-2.8.so lrwxrwxrwx 1 root root 9 Feb 4 2009 ld-linux.so.3 -> ld-2.o -rwxr-xr-x 1 root root 7542 Nov 18 2008 libBrokenLocale-2.8.so lrwxrwxrwx 1 root root 22 Feb 4 2009 libBrokenLocale.so.1 -o -rwxr-xr-x 1 root root 12603 Nov 18 2008 libSegFault.so -rwxr-xr-x 1 root root 14677 Nov 18 2008 libanl-2.8.so lrwxrwxrwx 1 root root 13 Feb 4 2009 libanl.so.1 -> libanl-o -rwxr-xr-x 1 root root 1565653 Nov 18 2008 libc-2.8.so lrwxrwxrwx 1 root root 11 Feb 4 2009 libc.so.6 -> libc-2.8.o -rwxr-xr-x 1 root root 189247 Nov 18 2008 libcidn-2.8.so lrwxrwxrwx 1 root root 14 Feb 4 2009 libcidn.so.1 -> libcido -rwxr-xr-x 1 root root 45479 Nov 18 2008 libcrypt-2.8.so lrwxrwxrwx 1 root root 15 Feb 4 2009 libcrypt.so.1 -> libcro -rwxr-xr-x 1 root root 15080 Nov 18 2008 libdl-2.8.so lrwxrwxrwx 1 root root 12 Feb 4 2009 libdl.so.2 -> libdl-2.o lrwxrwxrwx 1 root root 13 Feb 4 2009 libgcc_s.so -> libgcc_1 -rw-r--r-- 1 root root 69584 Nov 18 2008 libgcc_s.so.1 lrwxrwxrwx 1 root root 18 Oct 28 2011 libid3tag.so -> libid30 lrwxrwxrwx 1 root root 18 Oct 28 2011 libid3tag.so.0 -> libi0 -rwxr-xr-x 1 root root 235051 Sep 14 2011 libid3tag.so.0.3.0 -rwxr-xr-x 1 root root 30728 Jan 1 00:11 libiw.so.29 lrwxrwxrwx 1 root root 17 Oct 28 2011 libjpeg.so -> libjpeg.0 lrwxrwxrwx 1 root root 17 Oct 28 2011 libjpeg.so.62 -> libjp0 -rwxr-xr-x 1 root root 136104 Sep 14 2011 libjpeg.so.62.0.0 -rwxr-xr-x 1 root root 749831 Nov 18 2008 libm-2.8.so lrwxrwxrwx 1 root root 11 Feb 4 2009 libm.so.6 -> libm-2.8.o lrwxrwxrwx 1 root root 15 Oct 28 2011 libmad.so -> libmad.so1 lrwxrwxrwx 1 root root 15 Oct 28 2011 libmad.so.0 -> libmad.1 -rwxr-xr-x 1 root root 188424 Sep 14 2011 libmad.so.0.2.1 -rwxr-xr-x 1 root root 22795 Nov 18 2008 libmemusage.so -rwxr-xr-x 1 root root 103057 Nov 18 2008 libnsl-2.8.so lrwxrwxrwx 1 root root 13 Feb 4 2009 libnsl.so.1 -> libnsl-o -rwxr-xr-x 1 root root 35393 Nov 18 2008 libnss_compat-2.8.so lrwxrwxrwx 1 root root 20 Feb 4 2009 libnss_compat.so.2 -> o -rwxr-xr-x 1 root root 18312 Nov 18 2008 libnss_dns-2.8.so lrwxrwxrwx 1 root root 17 Feb 4 2009 libnss_dns.so.2 -> libo -rwxr-xr-x 1 root root 52001 Nov 18 2008 libnss_files-2.8.so lrwxrwxrwx 1 root root 19 Feb 4 2009 libnss_files.so.2 -> lo -rwxr-xr-x 1 root root 19807 Nov 18 2008 libnss_hesiod-2.8.so lrwxrwxrwx 1 root root 20 Feb 4 2009 libnss_hesiod.so.2 -> o -rwxr-xr-x 1 root root 51030 Nov 18 2008 libnss_nis-2.8.so lrwxrwxrwx 1 root root 17 Feb 4 2009 libnss_nis.so.2 -> libo -rwxr-xr-x 1 root root 57137 Nov 18 2008 libnss_nisplus-2.8.so lrwxrwxrwx 1 root root 21 Feb 4 2009 libnss_nisplus.so.2 ->o -rwxr-xr-x 1 root root 7849 Nov 18 2008 libpcprofile.so lrwxrwxrwx 1 root root 16 Oct 28 2011 libpng.so -> libpng.so0 lrwxrwxrwx 1 root root 16 Oct 28 2011 libpng.so.3 -> libpng.0 -rwxr-xr-x 1 root root 201040 Sep 14 2011 libpng.so.3.35.0 lrwxrwxrwx 1 root root 18 Oct 28 2011 libpng12.so -> libpng10 lrwxrwxrwx 1 root root 18 Oct 28 2011 libpng12.so.0 -> libpn0 -rwxr-xr-x 1 root root 189364 Sep 14 2011 libpng12.so.0.35.0 -rwxr-xr-x 1 root root 131890 Nov 18 2008 libpthread-2.8.so lrwxrwxrwx 1 root root 17 Feb 4 2009 libpthread.so.0 -> libo -rwxr-xr-x 1 root root 75532 Nov 18 2008 libresolv-2.8.so lrwxrwxrwx 1 root root 16 Feb 4 2009 libresolv.so.2 -> libro -rwxr-xr-x 1 root root 40807 Nov 18 2008 librt-2.8.so lrwxrwxrwx 1 root root 12 Feb 4 2009 librt.so.1 -> librt-2.o lrwxrwxrwx 1 root root 19 Oct 28 2011 libstdc++.so -> libstd0 lrwxrwxrwx 1 root root 19 Oct 28 2011 libstdc++.so.6 -> libs0 -rwxr-xr-x 1 root root 1250667 Sep 14 2011 libstdc++.so.6.0.10 -rwxr-xr-x 1 root root 36459 Nov 18 2008 libthread_db-1.0.so lrwxrwxrwx 1 root root 19 Feb 4 2009 libthread_db.so.1 -> lo -rwxr-xr-x 1 root root 13607 Nov 18 2008 libutil-2.8.so lrwxrwxrwx 1 root root 14 Feb 4 2009 libutil.so.1 -> libutio lrwxrwxrwx 1 root root 14 Oct 28 2011 libuuid.so -> libuuid.2 lrwxrwxrwx 1 root root 14 Oct 28 2011 libuuid.so.1 -> libuui2 -rwxr-xr-x 1 root root 15368 Sep 14 2011 libuuid.so.1.2 -rw-r--r-- 1 root root 92728 Mar 26 2009 libz.a
It should look like this: $ readelf -A <the-binary-to-test> Attribute Section: aeabi File Attributes Tag_CPU_name: "4T" Tag_CPU_arch: v4T Tag_ARM_ISA_use: Yes Tag_THUMB_ISA_use: Thumb-1 Tag_VFP_arch: VFPv2 Tag_ABI_PCS_wchar_t: 4 Tag_ABI_FP_denormal: Needed Tag_ABI_FP_exceptions: Needed Tag_ABI_FP_number_model: IEEE 754 Tag_ABI_align8_needed: Yes Tag_ABI_align8_preserved: Yes, except leaf SP Tag_ABI_enum_size: int Tag_unknown_44: 1 (0x1) The important line is "Tag_CPU_arch: v4T"
how to install linux-usb-wifi_linux-2.6.32.2_20100728 in mini2440 this contain lib usr folder and where you have copied into the
root@yargic-pc:~# readelf -A <the-binary-to-test> bash: syntax error near unexpected token `newline'
I check all binary .so Attribute Section: aeabi File Attributes Tag_CPU_name: "4T" Tag_CPU_arch: v4T Tag_ARM_ISA_use: Yes Tag_THUMB_ISA_use: Thumb-1 Tag_ABI_PCS_wchar_t: 4 Tag_ABI_FP_denormal: Needed Tag_ABI_FP_exceptions: Needed Tag_ABI_FP_number_model: IEEE 754 Tag_ABI_align_needed: 8-byte Tag_ABI_align_preserved: 8-byte, except leaf SP Tag_ABI_enum_size: int Tag_ABI_optimization_goals: Aggressive Speed
hi I have wireless broadcasting.seeing the broadcast in my PC and the Internet on Enter own computer When I wrote scan-wifi,mini2440 does not see wireless broadcasting start-wifi wpa SSID PASSWORD sh: udhcpc: not found scan-wifi 0 Access Point Found
from Juergen Beisert and dave armv4t problem Juergen Beisert It should look like this: $ readelf -A <the-binary-to-test> Attribute Section: aeabi File Attributes Tag_CPU_name: "4T" Tag_CPU_arch: v4T Tag_ARM_ISA_use: Yes Tag_THUMB_ISA_use: Thumb-1 Tag_VFP_arch: VFPv2 Tag_ABI_PCS_wchar_t: 4 Tag_ABI_FP_denormal: Needed Tag_ABI_FP_exceptions: Needed Tag_ABI_FP_number_model: IEEE 754 Tag_ABI_align8_needed: Yes Tag_ABI_align8_preserved: Yes, except leaf SP Tag_ABI_enum_size: int Tag_unknown_44: 1 (0x1) The important line is "Tag_CPU_arch: v4T"
