Hi, A friend told me about the FriendlyARM board and I have been trying to compile the stuff from this website. Thought I'd start with x86-Qtopia, write some code, use the simulator, buy a board, play, usual stuff. I am new to Linux, but not to embedded programming, that has been my career for nearly 30 years. I followed the steps on the Equally Bad blog (thanks for that work by the way, that made the initial steps sooooo much easier for a Linux beginner). First problem I had was in camera.pro videocaptureview.cpp threw an error on the line. #include <linux/videodev.h> the file is there but it couldn't find it, anyway I hacked the line to be: #include </opt/FriendlyARM/toolschain/4.4.3/arm-none-linux-gnueabi/sys-root/usr/includ e/linux/videodev.h> now the file compiles, not an elegant solution, but I want to get this thing built. Next problem: /opt/FriendlyARM/mini2440/x86-qtopia/qtopia-2.2.0-FriendlyARM/qtopia/lib/libqtop ia.so: undefined reference to `uuid_generate' While making minesweeper. I found various references to this error that suggested adding -luuid to the linker, which I did, but it still won't work. I am using Ubuntu 11.10 by the way, though I can't see why either of these errors would be OS related. arm-qtopia won't build either, but one step at a time! Anyone able to help me here please? I am starting to pull what little hair I have left out :) Cheers. Dui.
Compiling x86-Qtopia
So I find I didn't have x11R6 in the \usr directory (or anywhere for that matter) The make process didn't show an error, it just kinda stopped, which is weird (to me) I downloaded the latest version (x11R6.8.1), and of course that doesn't compile. ../include/qmap.h:604:13: error: ‘ptrdiff_t’ does not name a type. I'm guessing the latest version is too new. Any pointers to which version I need would be very helpful. Thanks in advance.
You are new to Linux and you decided to start by compiling a new system? The Linux kernel and file system that ships on the boards is perfectly serviceable and has demos of the I/O. Why not use the included too chain and try some simple applications? Certainly jumping into the cubicly complicated combination of Linux*embedded*(configure and build) by building a new system is the most error prone approach.
Thanks for your reply. I went this route because I read killfire's excellent blog and it mentioned that by compiling x86qtopia you could run an emulator on the PC. I haven't actually bought a board yet, I downloaded everything from this site. I wanted to check the dev tools out and the instructions in the blog made it look simple, so I followed them. There is another (long) thread about compiling this stuff and it seems like many people have many different problems, but no one seems to have had the problems I am having. This is almost certainly due to lack of familiarization with the OS and the toolchain. There are probably other packages that I need to download and install before everything works, but as a complete Linux beginner, I have no idea what they are (the x11R6 package is a good example of that) I'm not too concerned about compiling the kernel (though I find the number and type of errors worrying), just want the emulator, I assumed (perhaps wrongly) that x86qtopia needed to be compiled to run that.
I did assume wrongly... I have ./run-hello working in the emulator. 3 hardcoded path "errors" in the script needed to be corrected, but at least it works now and I can play. Thanks for setting me off in the right (or at least different) direction.
g++ -o minesweep .obj/release-shared/minefield.o .obj/release-shared/minesweep.o .obj/release-shared/main.o .obj/release-shared/moc_minefield.o .obj/release-shared/moc_minesweep.o -lqtopia2 -lqtopia -lqpe -L/root/yizhi/host/qtopia-free-2.2.0/qtopia/lib -L/root/yizhi/host/qtopia-free-2.2.0/qt2/lib -lqte /root/yizhi/host/qtopia-free-2.2.0/qtopia/lib/libqtopia.so: undefined reference to `uuid_generate' collect2: ld 返回 1 make[6]: *** [minesweep] 错误 1 make[6]:正在离开目录 `/root/yizhi/host/qtopia-free-2.2.0/qtopia/src/games/minesweep' make[5]: *** [all] 错误 2 make[5]:正在离开目录 `/root/yizhi/host/qtopia-free-2.2.0/qtopia/src/games/minesweep' make[4]: *** [sub-games-minesweep] 错误 2 make[4]:正在离开目录 `/root/yizhi/host/qtopia-free-2.2.0/qtopia/src' make[3]: *** [sub-src-components_pro] 错误 2 make[3]:正在离开目录 `/root/yizhi/host/qtopia-free-2.2.0/qtopia/src' make[2]: *** [install] 错误 2 make[2]:正在离开目录 `/root/yizhi/host/qtopia-free-2.2.0/qtopia/src' make[1]: *** [install] 错误 2 make[1]:正在离开目录 `/root/yizhi/host/qtopia-free-2.2.0/qtopia'
after you install libv4l-dev sudo ln -s /usr/include/libv4l1-videodev.h /usr/include/linux/videodev.h
