I have a cam130 I tested it and worked. and I am going to buy a wifi module. but first I wanted to get stream. I download mjpeg last day. ./start_sc2410.so //I run this code and . my pc browser write 192.168.1.230:8080/stream_simple.html but it is not connect. I built a rootfs 2 mount ago. I may built wrong my rootfs. I am able to run gpio-pwm-button-camera from my_project-qws I am very sad. I am very happy if you help me.
I don't connect mini2440 from my pc
Are you asking how do you connect a PC to the mini2440 via Ethernet? Or do you want to know serve up the page stream_simple.html? For the first, just connect the mini2440 into your local network. As I am finding out, trying to connect it directly to a PC sometimes works and sometimes doesn't. Use a hub. For the second, are you running a web server on the mini2440? Boa as in FriendlyArm distros or your own web server?
fistly thank you very much I dont very much net procedure. I transfer video to pc from mini2440 and control gpio. for example wifi robot project . I dont know which path to follow. you show me path I decided to establish a new root 'Good video and wifi module to run qws ' 1. What should I do first 2. Which programs should I use What do you advise me
> and . my pc browser write 192.168.1.230:8080/stream_simple.html > but it is not connect. I was only trying to offer suggestions for what seemed to be your problem. Can't help with the rest of it. Good luck
ok thank you I saw the wep site mjpeg_stream in pc browser adress 192.168.1.230:8080/stream_simple.html l dont know very much l will use a hup. how to connect and transfer video to computer and mini2440. I am very happy if you help me
hello I want to write a program with QT creater and I want to control gpio and video(cam130). I connect to use wifi to mini2440 from my pc . which rootfs? and how set up rootfs for connection. I look forward to your advice.
how do you do it?? I ported android in my mini2440 x35 and then pluged the ethernet to my laptop but i can't telnet to it.I ping 192.168.1.230 and it success but telnet ditn't Anyone can help?
