I'm attempting to install Pengutronix to my mini2440, and when I get to the portion where I need to login, the following occurs: ____ _______ __ | _ `_ _` `/ / | |_) || | ` / | __/ | | / ` |_| |_| /_/`_` _ _ ____ _ _ _ _ ___ _ __ ___ (_)_ __ (_)___ `| || | | || | / _ ` | '_ ` _ `| | '_ `| | __) | || |_| || |_| | | | | | | | | | | | | | |/ __/|__ _|__ _| |_| | |_| |_| |_|_|_| |_|_|_____| |_| |_| `___/ OSELAS(R)-Mini2440-2011.12.0 / mini2440-2011.12.0 ptxdist-2012.01.0/2012-01-21T18:42:33-0500 mini2440 login: root Password: Login incorrect I am entering "root" as login, and nothing as password, just hitting enter, and it tells me login incorrect. Does anybody know if it requires a proper password, or how I can fix this so that I can use root with no password?
Pengutronix first root login problem
I noticed that you are running: ptxdist-2012.01.0/2012-01-21T18:42:33-0500 Are not the BSP and ptxdist versions supposed to be the same? And 2011.12 was the last BSP
Let's try again: If you get the login correct you should not be asked for a password. So, try again. If that doesn't work maybe you have messed with your passwd file.
Ok, I tried recompiling everything with the current version I'm using. It still says Login incorrect, so now I'll try different versions and try to match them and see if it works.
Did you add a file like "projectroot/etc/passwd" into you project or did you change the content of the "<ptxdist-install-path>/generic/etc/passwd"? One of these files will be used to create the "/etc/passwd" file on your running Mini2440. And the one from the PTXdist installation defines the user root without a password. Strange. Never seen this kind of failure from our generic BSPs.
I also notice that there are not any lines after: OSELAS(R)-Mini2440-2011.12.0 / mini2440-2011.12.0 ptxdist-2012.01.0/2012-01-21T18:42:33-0500 that tell you which tty you are using. Have you got virtual terminal enabled so that you can see stuff on the FriendlyArm? Shows us your /etc/inittab
Ok, I tried compiling everything with version 2011.11.0, and I got some errors along the way that prevented me from compiling the BSP, so I will go back to the versions I used when I got the error from my original post, and I will post the information requested when I get up to there. As for the passwd file, I didn't touch it at all, so when that directory is created again, I'll check on it.
Okay. Juergen, There is no file like "projectroot/etc/passwd", the contents of "<ptxdist-install-path>/generic/etc/passwd" remain unchanged and are as follows: root:x:0:0:root:/home:/bin/sh daemon:x:1:1:daemon:/usr/sbin:/bin/sh ftp:x:11:101:ftp user:/home:/bin/false www:x:12:102:www user:/home:/bin/false sshd:x:100:65534:SSH Server:/var/run/sshd:/bin/false messagebus:x:103:104:messagebus:/dev/null:/bin/false rpcuser:x:65533:65534:RPC user:/dev/null:/bin/false nobody:x:65534:65534:Unprivileged Nobody:/dev/null:/bin/false and the error persists. davef, I can't find any sort of file in /etc named inittab. For picocom, I'm using ttyS4, and in picocom, I'll paste here the same as my original post, but with the line preceding: starting pid 405, tty '/dev/console': '/sbin/getty -L 115200 ttySAC0 vt100' (ASCII art saying PTX mini2440) OSELAS(R)-Mini2440-2011.12.0 / mini2440-2011.12.0 ptxdist-2012.01.0/2012-01-22T18:16:44-0500 mini2440 login: root Password: Login incorrect The mini2440 itself shows nothing on the screen. The versions of files I'm using are as follows: ptxdist-2012.01.0.tar.bz2 OSELAS.Toolchain-2011.11.0.tar.bz2 OSELAS.BSP-Pengutronix-Mini2440-2011.12.0.tgz
davef, I found a few /etc/inittab files. platform-mini2440/generic/etc/inittab is: # # /etc/inittab # console::sysinit:/etc/init.d/rcS console::respawn:/sbin/getty -L @SPEED@ @CONSOLE@ vt100 # Stuff to do before rebooting ::ctrlaltdel:/sbin/reboot ::shutdown:/bin/umount -a -r platform-mini2440/root/etc/inittab and platform-mini2440/root-debug/etc/inittab are both: # # /etc/inittab # console::sysinit:/etc/init.d/rcS console::respawn:/sbin/getty -L 115200 ttySAC0 vt100 # Stuff to do before rebooting ::ctrlaltdel:/sbin/reboot ::shutdown:/bin/umount -a -r platform-mini2440/build-target/busybox-1.18.5/examples/bootfloppy/etc/inittab is: ::sysinit:/etc/init.d/rcS ::respawn:-/bin/sh tty2::askfirst:-/bin/sh ::ctrlaltdel:/bin/umount -a -r Don't know how much these help, but I hope they do.
Is /etc/inittab not ending up in your root filesystem? Sounds like a problem. starting pid 405, tty '/dev/console': '/sbin/getty -L 115200 ttySAC0 vt100' comes after: OSELAS(R)-Mini2440-2011.12.0 / mini2440-2011.12.0 ptxdist-2012.01.0/2012-01-22T18:16:44-0500 on all versions of PTXdist that I have run over the last 6 months. Seems odd. > For picocom, I'm using ttyS4, and in picocom, I'll paste here the same as > my original post, but with the line preceding: > starting pid 405, tty '/dev/console': '/sbin/getty -L 115200 ttySAC0 > vt100' Have you got ttyS4 enabled as a serial port? Why not put picocom on ttySAC0 as a starter?
What is the full location of /etc/inittab, maybe I'm missing something? And for the serial port, I don't know if it's activated or not, I just enter "sudo picocom -b 115200 /dev/ttyS4" when starting picocom. That's all I know about the serial port. Are you suggesting using "sudo picocom -b 115200 /dev/ttySAC0" instead?
The full location is /etc/inittab Yes, Unless you enable the serial port for read/write it won't work. For example: chmod 666 /dev/ttySAC1 Why are you trying to use ttyS4?
if /etc/inittab is the full location, then I seem to be lacking that file. The picocom tutorial page I found said to to use ttySx with x as port number. It was showing vivi, so I assumed it worked fine. I don't have anything in /dev file like /ttySACx either, only ttySx files. I'm pretty sure my serial port is indexed as ttyS4 since that is the only way I can communicate with the mini. Am I doing something very wrong?
Are you using the default kernel config, as found in the mini2440 2011.12 BSP? Or are you selecting one of the other kernel configs? Not seeing any ttySACx seems to be a major problem.
If you look into /platform-mini2440/root/etc you should see an inittab. This should be on your target. So, "ptxdist go" and "ptxdist images" work without errors. How are you getting your kernel and root filesystem unto the mini2440?
I'm following this guide: http://wingston.workshopindia.com/wingz/embedded-programming-on-the-mini... I'll try and explain everything I did. ptxdist setup: -go into extracted directory, -$./configure -$make -$make install -(skipped ptxdist setup since there is nothing to change) Toolchain compilation: -extract toolchain to /opt/OSELAS.Toolchain.etc. -$ptxdist select ptxconfigs/arm-v4t-linux-gnueabi_gcc-4.6.2_glibc-2.14.1_binutils-2.21.1a_kernel- 2.6.39-sanitized.ptxconfig -$ptxdist migrate -$ptxdist go BSP compilation: -extract BSP and navigate to it. -Modify barebox-128m-env config file with network things, tftp, and nfs root directory -$ptxdist select configs/ptxconfig -$ptxdist platform configs/platform-friendlyarm-mini2440/platformconfig-NAND-128M -$ptxdist migrate (Here i kept hitting enter taking default options when it asked for extra packages to install, which ended up installing no extra packages) -$ptxdist go -$ptxdist images (Everything worked fine) Bootloader through tftp: -Mini connected through ethernet, usb, and serial. -opened seperate terminal and ran: $sudo picocom -b 115200 /dev/ttyS4, picocom waits for mini -set mini to NOR and turn on, this brings up the vivi bootloader in picocom -in the first terminal (in BSP folder) ran: $sudo platform-mini2440/sysroot-host/bin/usbpush platform-mini2440/images/barebox-image -mini boots into this and I stop the autoboot bringing me to the mini2440:/ command line -copy barebox-images to my tftp folder and rename it as barebox-mini2440 -run on mini: mini2440:/ update -t barebox -d nand -bootloader is now on mini and I can switch back to NAND and come up with this same command line through picocom. Linux Image: (where the problem is) -move linuximage to tftp folder renaming as uImage-mini2440 -set up NFS so it speaks to mini -start up mini in NAND mode, let it autoboot, and it grabs uImage-mini2440, booting into the screen where I need to input login and password. This is where I input root as login and nothing as the password and it says it is incorrect.
Go into documents and read through the Quickstart guide. First, I have been told that ptxdist migrate is for experts only. I got into a mess several times, which I solved by deleting unwanted PTXdist files in home/.ptxdist You only need ptxdist 2011.11 to build the toolchain (I then delted any reference to it in home/.ptxdist, then build ptxdist 2011.12 and lastly build the BSP 2011.12. No migrates or --force required. There is another method to do this properly by making softlinks to the version you want. Search Pengutronix blogs on gmane, they are linked to from their website. To save yourself future grief there is one thing you want to set up in ptxdist and that is where your downloaded source files exist OR you will download them everything you make a kernel/root filesystem. I save them in /home/ptxdist/all_src Your procedure does not describe actually putting the root filesystem on the mini2440. The root filesystem should include /etc/inittab :) Still curious why ttyS4?
Forget the last comment I haven't used NFS on this for the last few months. delted = deleted everything = everytime
Okay, that's a whole lot to take in. I think I'm going to have to try all that tomorrow because it's getting late and I've used my allotted brain power for the day. Just to clear up before I start in the morning, I install ptxdist 2011.11.0 when compiling toolchain 2011.11.0 and I install ptxdist 2011.12.0 when compiling BSP 2011.12.0? And if so, when I do this and I type ptxdist go, it will not make me migrate or force at all? Does this mean that migrate/force is when the ptxdist version does not match the files being compiled? Thanks a lot! I will post with results at some point tomorrow hopefully.
I hope so! > Does this mean that > migrate/force is when the ptxdist version does not match the files being > compiled? . . . does not match the mini2440-BSP version. When you have a properly operating toolchain save your /opt directory, just in case you lose it! The rest of builds are much shorter! Good luck
http://article.gmane.org/gmane.comp.embedded.ptxdist.oselas.community/73... I think the link only needs to be in the BSP that you are working with. If you are trying to use multiple toolchains, you probably have to do something more, as suggested. Stick with one toolchain and one BSP version. It will be easier now because they are only coming out every 3 months :) Also, are you sure your NFS setup is working properly?
Hi Pants, you say the passwd file in your root filesystem is the same as the one from the PTXdist installation directory. So, there is no password for the root defined. Maybe something goes wrong when your target asks you for username. What is your setting for <enter> in your terminal? CR, LF or CF+LF? It's just a shot in the dark. Another idea: You can start your kernel with the parameter "init=/bin/sh" to get a shell on your target (without a login prompt). Maybe this will discover something. And the logfile would be of interst for me: please send the file "platform-mini2440/logfile" (compressed) to my account jbe at pengutronix dot de after you have built the whole BSP ("ptxdist go"). And, after running the command "ptxdist image" please send me also the result archive "platform-mini2440/images/root.tgz"
Can someone let me know how to properly/fully uninstall ptxdist before I reinstall a different version?
If you want to de-install it, just remove the '/usr/local/lib/<ptxdist-version>' and the corresponding link in '/usr/local/bin/ptxdist-<version>', and the file(s) from '$HOME/.ptxdist'. That's all. It does not pollute your system with shared libraries or something like that. And: you can install all versions side by side. The do not conflict! You only need some mechanism to always use the correct one in your project (me sets up a link in every project to the correct versions. And then I use only the link to call ptxdist): $ ln -s /usr/local/lib/ptxdist-2012.01.0/bin/ptxdist p $ ./p menuconfig $ ./p go $ ./p images (and so on)
Hi Pants, I tried your root filesystem archive you sent me, and it works as expected. I can login as 'root' without a password.
Interesting... Does it matter where I am located in the terminal to link them? or can I do it from anywhere?
Yes, davef. I don't get why everyone else has their serial port as ttySAC0 but mine is recognised as ttyS4.
Where is it recognised as ttyS4? /dev? You have your serial cable connected to the 9pin D range, right? Unmodified mini2440?
Serial cable connected from pci card in computer up to mini's only 9-pin serial port. It is recognized as ttyS4 on my ubuntu machine in /dev.
> It is recognized as ttyS4 on my ubuntu machine in /dev. If you can't log into the mini2440 and look at /dev on the target, how can you determine which tty it is using? Are you looking at the serial port being used by the ubuntu machine?
I just tried it because you got me curious. If I replace ttyS4 with ttySAC0 (I tried ttyS0-ttyS6), it doesn't activate at all. ttyS4 seems to be the only one that works.
> ttyS4 seems to be the only one that works. But, it doesn't seem to work properly. If you have done a default kernel compilation, I think the FriendlyArm touchscreen should work (virtual terminal in kernel config). Does anything show up on the touchscreen?
Nothing shows up on the screen at all during the process. It flashes a couple times, then either stays off, or keeps the backlight on depending on which stage I'm in, but never does it have any sort of UI.
Here's what you might have to do in the kernel: http://article.gmane.org/gmane.comp.embedded.ptxdist.oselas.community/58... and /etc/inittab needs another entry: console::respawn:/sbin/getty -L 9600 tty1 vt100 That is from memory. Now, you should be able to work from the FA and then later work out why you can't talk to it from the host.
in inittab the line: console::respawn:/sbin/getty -L 115200 ttySAC0 vt100 is already there. Do I replace this line with: console::respawn:/sbin/getty -L 9600 tty1 vt100 or just place this new line below it?
Okay, I tried running it again, and it still isn't working. I get a new error after incorrect login: starting pid 423, tty '/dev/console': '/sbin/getty -L 9600 tty1 vt100' process '/sbin/getty -L 115200 ttySAC0 vt100' (pid 420) exited. Scheduling for restart. or starting pid 415, tty '/dev/console': '/sbin/getty -L 9600 tty1 vt100' process '/sbin/getty -L 9600 tty1 vt100' (pid 415) exited. Scheduling for restart. Should I just start over from scratch, or will I just end up making the same mistake if I don't know what I'm doing?
You should get those before the login prompt comes up. Going back to previous comments I don't understand why those prompts are being announced in an unusual place. Also, those errors you get do they keep repeating themselves? I have had that happen as well, which was cured by the changes just above. I think we need to back-up a bit. Which variant mini2440 and LCD are you using?
I'm using the mini2440 with 128M NAND, and the W35i screen. I think I'm just going to start the process over and see if I can avoid this by following the quickstart guide instead of the online guide I was using.
Good idea. A lot of work has gone into that document. Anything which makes it easier to get results quickly, I am sure would be appreciated. W35i, better search that screen out on here, I think it caused a few problems. Did you ever run the original FriendlyArm distro successfully?
Try to login into your Mini2440 target via telnet. Does it work in this way (also 'root' without password)? If it works this way then run the 'getty' line manually from this console, but with "strace" please. root@mini2440: strace /sbin/getty -L 115200 ttySAC0 vt100 When this line is running you should see an new message in your serial terminal. Then try to login in this terminal and watch what 'getty' really does. Maybe the log of the 'strace' output would be of interest for us. BTW: 'ttyS' versus 'ttySAC': 'ttyS' is the device node name for all 8250 based UARTs. 'ttySAC' is the device node name for Samsung UARTs, like the ones in the S3C2440 CPU. So, you can use the 'ttyS' only on your x86 based host, not at the Mini2440 side. And the 'ttySAC' can only be used at the Mini2440 side, not at your x86 based host. So, everything is all right, if the Mini2440 uses the "ttySAC0" and your host uses the 'ttyS4'.
I re-did the whole process, I used the 2 different typed of ptxdist to match both the Toolchain, and the BSP, and I did steps that I missed when using the other tutorial, and now, I am finally able to log in as root. The filesystem and kernel are both transferred to nand, and I can boot the mini into linux while connected to my computer through picocom with no problems. I just want to confirm that there is nothing shown on the lcd and all work is done through the terminal on the host computer. Now I need to find out how to use PWM to drive servos and see if there is a way I can make this work in real time :D Thanks everyone for the help.
> I just want to confirm that there is nothing shown on the lcd and all > work is done through the terminal on the host computer. Re-read the previous comments about activating the touchscreen. Any problem there just post your bootup messages. Good to hear you got there in the end. Something I think that would have resolved things sooner is you need the answer questions that people put to you. The query about ttys4 occurred about 1/2 the way through this thread. Good luck with the PWM.
Pants, Perhaps to tidy off the job advise Wingston what he missed and suggest against using ptxdist migrate. I was "told off" by the PTXdist gurus! Dave
The thing is : everytime i did a ptxdist go from a new setup it always gives an error because of some config file and to run ptxdist migrate to fix it. When i do run migrate, it asked for (i think) all the new entries a y/n option which i always do no to. what are the exact missing steps? (for me to add them) :)
See the link to gmane above. The way I was doing it was a "workaround" the correct way is to make links. I suggest the following: ******************** Section 3.3.3 Before building the toolchain make a link to the correct PTXdist to build that toolchain, ie: $ ln -s /usr/local/bin/ptxdist-2011.11.0 p then change all calls to ptxdist to ./p for example ./p select ptxconfigs/armv4t- . . . ./p go Section 4.3 Before building the kernel and root filesystem, delete the above link and make a new link: $ ln -s /usr/local/bin/ptxdist-2011.12.0 p then change all calls to ptxdist to ./p for example ./p select configs/ptxconfigs ******************* I haven't tested this, so I'd suggest you try it out before publishing.
you must change attribute of "passwd" and "shadow" file in /etc/ to be writeable readable and excute by command : sudo chmod a+rwx /etc/passwd sudo chmod a+rwx /etc/shadow and then reboot your mini2440 board login with root user without password.
BTW: What issue should this change solve? The 'passwd' and the 'shadow' files do never need execution permission. And it is a really bad idea (and a huge security hole) to make the 'shadow' file world read and write able.
I agree with Juergen Beisert. It's not safe for that permission of files. So sorry that is my bad habit to change permission of files. just only use sudo chmod a+r /etc/password sudo chmod a+r /etc/shadow it's enough for login to mini2440 linux. It can be solve login incorrect problem. (I got this problem too and can be solved be this solution)
To keep the read permission for all is still no solution. It seems in your system something is wrong with the user ids, the processes are running on. The login process runs as root. So, there should be no problem to be able to read the /etc/shadow, even if this file has only 0400 permissions. BTW: how did you change the permissions of this file, when the login fails?
I'm new in mini2440 just like Mr.Pants. This is the first time I use this board and I have the save problem as him. Then I solved the problem by using chmod a+r method. I see the permission of passwd and shadow file have read permission on root only. and then I change that permission to readonly to all of user by chmod a+r. it can work properly but I don't know why. I use the linuxkernel, root.nffs2 file and extract root.tgz to nfs. I change passwd and shadow permission with my ubuntu. Am I setup or config something mistake?
I tried it here with the sparse information I have about your environment. When I extract the root.tgz archive anywhere in my filesystem, exporting this directory via NFS server but with the 'root_squash' option set I also get: mini2440 login: root Password: Login incorrect After adding the 'a+r' to the etc/shadow I can login into this system. This could be a solution, but its not the cause of your trouble: You must take into account at the Mini2440's side the user 'root' is working. Some things at system start-up have to be done as root, because for some actions only root has the permissions to do so. But now you are using an NFS root filesystem. And the user 'root' at the Mini2440 side depends on the permissions to act as 'root' also in the filesystem. But the NFS server option 'root_squash' (the default) prevents any external host from being 'root' on the local filesystem. So, the 'root' at the Mini2440 fails when it tries to access special files in the NFS root filesystem (in your case it fails to access the etc/shadow). Real solution: add the 'no_root_squash' option to the exported filesystem and the Mini2440's 'root' is also 'root' at your local filesystem (with all risk, drawbacks and security holes, so never export the your whole filesystem in this way).
