i'm writing an app using the necessitas QT creator IDE. i have a mini6410 running android. i can write my app, deploy the .apk file to the device just fine. i put the .apk on an sdcard from the host system, then plug it into the mini6410 and install. works fine. i'm doing this on my macbook. so, i want to do live debugging on the mini6410. i've done all the things i think i need to do to make it work. i've gone and checked settings->applications->unknown sources. i set settings->development->usb debugging. plug the mini6410 into the macbook, it doesn't seem to see it. i tried each of the three usb ports, same result. when i plug this same 6410 into my windows system, it doesn't seem to see it either. when i compile the app with QT creator, it compiles then says 'please wait, searching for a suitable device for target:android-7'. anyone have any ideas on what i need to do to make this work?
mini6410 debug w/QT
update: the mini6410 isn't seen by windows at all. i have device manager open, plug it in, nothing happens. no unknown device, etc. i can plug in a USB stick into the 6410, it sees it just fine. i can also power the 6410 over usb, so that's not the problem.
