I am trying to get a little tryout program to work. It is basically a copy
of the lcd test/example code on the site.
I want to count the number of touches in the "touch" interrupt and have
have the main loop wait 2 second before displaying the number of touches
and clearing it. However it seems as if the variable is not shared between
the interrupt and the main code.
Can anyone tell me what I might be doing wrong?
This my code:
#include "def.h"
#include "option.h"
#include "2440addr.h"
#include "2440lib.h"
#include "2440slib.h"
volatile int click_count = 0;
U32 click_section;
#define REQCNT 30
#define ADCPRS 9 //YH 0627
#define LOOP 1
int combined_count=0;
volatile int combined_xdata, combined_ydata;
void __irq Combined_AdcTsAuto(void)
int i;
U32 saveAdcdly;
if(rADCDAT0&0x8000)
//Uart_Printf("\nStylus Up!!\n");
rADCTSC&=0xff; // Set stylus down interrupt bit
//else
//Uart_Printf("\nStylus Down!!\n");
rADCTSC=(1<<3)|(1<<2); //Pull-up disable, Seq. X,Y postion
measure.
saveAdcdly=rADCDLY;
rADCDLY=40000; //Normal conversion mode delay about
(1/50M)*40000=0.8ms
rADCCON|=0x1; //start ADC
while(rADCCON & 0x1); //check if Enable_start is low
while(!(rADCCON & 0x8000)); //check if EC(End of Conversion)
flag is high, This line is necessary~!!
while(!(rSRCPND & (BIT_ADC))); //check if ADC is finished with
interrupt bit
combined_xdata=(rADCDAT0&0x3ff);
combined_ydata=(rADCDAT1&0x3ff);
//YH 0627, To check Stylus Up Interrupt.
rSUBSRCPND|=BIT_SUB_TC;
ClearPending(BIT_ADC);
rINTSUBMSK=~(BIT_SUB_TC);
rINTMSK=~(BIT_ADC);
rADCTSC =0xd3; //Waiting for interrupt
rADCTSC=rADCTSC|(1<<8); // Detect stylus up interrupt signal.
while(1) //to check Pen-up state
if(rSUBSRCPND & (BIT_SUB_TC)) //check if ADC is finished with
interrupt bit
//Uart_Printf("Stylus Up Interrupt~!\n");
break; //if Stylus is up(1) state
EnterCritical(&click_section);
click_count++; // Increase the counter!
ExitCritical(&click_section);
rADCDLY=saveAdcdly;
rADCTSC=rADCTSC&~(1<<8); // Detect stylus Down interrupt signal.
rINTSUBMSK=~(BIT_SUB_TC); // Unmask sub interrupt (TC)
// Test
void Test_Combined(void)
int jaap;
// Start touch
rADCDLY=50000; //Normal conversion mode delay about
(1/3.6864M)*50000=13.56ms
rADCCON=(1<<14)+(ADCPRS<<6); //ADCPRS En, ADCPRS Value
Uart_Printf("ADC touch screen test\n");
rADCTSC=0xd3; //Wfait,XP_PU,XP_Dis,XM_Dis,YP_Dis,YM_En
pISR_ADC = (int)Combined_AdcTsAuto;
rINTMSK=~BIT_ADC; //ADC Touch Screen Mask bit clear
Uart_Printf("\nType any key to exit!!!\n");
Uart_Printf("\nStylus Down, please...... \n");
// Started touch
// Wait for a esc key on serial
while( Uart_GetKey() != ESC_KEY )
for(jaap=0; jaap<click_count; jaap++)
Uart_Printf("LOOP!!!\n");
click_count = 0;
Uart_Printf("Tic!!!\n");
Delay(2000);
// Stop keyscan
DisableIrq(BIT_EINT0|BIT_EINT2|BIT_EINT8_23);
// Stopped keyscan
P.S. I know my naming conventions are bad ;-)
Interrupts and violate variables
Actually you don't need those 3 global variables above to be declared volatile. Bad copypaste practice:)
