stuck on unable to open initial console
nithin
Hi all,
    am nithin. I am using mini2440 board. While I tried to load linux OS on
it, its showing a warning: Unable to load initial console, and standing
idle.
     I am using buildroot-2011.05 and created a tarred rootfs from it.
Linux OS which i am using is 2.6.32.2. I created zImage from it.
In the NOR flash itself, I selected z option for tranfering zImage through
USB. And I set linux command line option for booting from nfs.
While I checked my dev directory in Rootfs, there is one node named
console. It was like
crw------- 1 root root 5, 1 2012-01-16 21:32 /dev/console
Can anyone please tell me a solution for this issue.
nithin
Sorry that list information of node is having small change, It is
crw-r--r-- 1 root root 5, 1 2012-01-16 22:45 dev/console
Juergen Beisert
Do you use the kernel based NFS server at you host? The userland based NFS
server cannot export device nodes. Maybe this is the cause your kernel
fails to access the device node 'console' in your exported filesystem. BTW:
Are you sure the target mounts the correct filesystem?
Jaacs Job Pottas
I am also experiencing the same problem. 'Console' file is not present in
filesystem
Jaacs Job Pottas
I am also experiencing the same problem. console file is not present in
file system
Jaacs Job Pottas
Ok I solved the problem.
I am using nfs boot.. i tried untarring the filesystem with sudo. Now my
/dev directory contains console file!! :-)
