Touch screen too slow with linux 3.1
miniarm
Hello Jeurgen,
I have build linux 3.1 using ptxdist toolchain. kernel compile and
installed successfully with touch screen working. However when I run
/bin/qt4  touch screen responding very slow, Application open and working
but its too slow. can you please post a workarround for the same?
regards,
miniarm
Juergen Beisert
Can you check with the "evtest" tool if the touchscreen itself is slow or
if the sample pre-processing in the tslib makes it slow?
miniarm
Hello Juergen,
Thanks for the prompt reply, Sure, I will test and respond asap.
Thanks a lot.
miniarm
