Has anyone got an ideas about this problem, please? I've configured NFS on my dev machine (Fedora 16) and I can see the exported filesystems from another PC. However, when I try to mount one to the mini6410, I get the following: root@FriendlyARM /etc]# mount -t nfs4 ermintrude:/home/jeff/ARM /mnt mount: mounting ermintrude:/home/jeff/ARM on /mnt failed: No such device Googling that mount error, and checking lsmod, it looks as if the FriendlyARM kernel doesn't have NFS enabled. Could that be the case? The manual implies that it's there by default. Thanks!
NFS "no such device"... is NFS even in the kernel?
Take a look at run-time into the file "/proc/filesystems". When your kernel supports NFS, it should contain something like "nodev nfs".
Ah, my bad! Seems it's not -t nfs4, it's just -t nfs. So, now we get this: [root@FriendlyARM /]# mount -t nfs 192.168.1.202:/home/jeff/ARM /mnt mount: mounting 192.168.1.202:/home/jeff/ARM on /mnt failed: Connection refused Thought that might be SELinux raising its ugly head, but moving it to Permissive mode gives no change. All the ports listed by "rpcinfo -p" are open in the firewall, and even disabling the firewall temporarily has no effect. Odd. Juergen, /proc/filesystems on the mini6410 is empty... problem?
Is the whole 'proc/' empty? If yes, you forget to mount the procfs. If only the '/proc/filesystems' is empty, hmmm, no idea what wrong in this case. Mounting an NFS share can fail due to the 'mount' commend itself and its capabilities. The Busybox's 'mount' can handle NFS filesystem when enabled in its configuration. The regular 'mount' command needs the NFS helpers to be able to mount an NFS share.
Hmm indeed. proc looks ok. Might be something about how the latest Fedora builds use it - quite a few things aren't "standard" in the old way any longer. The 6410 doesn't seem to get it right with any remote filesystems. CIFS (Samba) mounts to my Windows server come back with "no such device" even with anonymous access enabled and NFS to the Windows server gives "connection refused" or "bad file descriptor" depending on its mood! When you say "when enabled in its configuration", where is that config on the ARM board?
And this is odder still... I just increased the logging level on the Windows server's NFS service. ARM: > busybox mount 192.168.1.2:/TransferTemp /pc mount: mounting 192.168.1.2:/TransferTemp on /pc failed: Connection refused [same answer for just "mount" without invoking busybox] Windows event log: Mount operation succeeded. Address:192.168.1.222 (that's the ARM board) Share:D:\Public\TransferTemp Now that's strange. ARM thinks it didn't work, Windows says it did.
Ah! I missed an option which appears to be vital to the mount. Thought it was the default, but possibly not in the ARM linux distro. It's mount -t nfs -o nolock etc... The "nolock" is the bit that made it work. Now I can mount nfs at least. CIFS doesn't matter, so will ignore that!
