Rebuild android for tiny6410
ndkhoa
Hi!!!
Help me.
I am working in eclipse and created some app android. I want rebuild
android and then install android for tiny6410 board.
Thank!!!.
Dave McLaughlin
Hi, are you running with Linux (Ubuntu is ideal)
You need to be using 64 bit if you want to build Gingerbread. It is not
difficult to setup and get it working but it will require a bit of work to
get all the bits you need to build Android. Hope also your PC is fast as
the build process is long and the faster your PC the better. My old laptop
was a 1.7Ghz and it took over 12 hours to build on that. The desktop with a
3.2Ghz AMD was about 4 hours in total.
Look around on the web for all the setup information. Google itself has a
lot of usefull information to do this.
Have you got the latest DVD images from this websites FTP? You'll need
these to get the source for Android.
Once you have all the above you can try building it. If you are not
familiar with Linux then it will take a little learning but if you stick at
it as I did (I was brand new to Linux) then you will get it going.
Good luck and have fun.
Dave...
