Hey everybody, i'm actually a student and i look for solution about the input/ouput of the mini2440 (with linux). When i try to access to the registers with a memory adress (found on datasheet) i've a segmentation fault. And i'm pretty sure about the adress number, for exemple : #define GPBCON (*(volatile unsigned long*) 0x56000010) I include the librairie with all the declaration (i work in C) and i do just a little programme with just an acess to GPBCON the compilation is good (i've the cross compilater installed) but the execution make a segmentation fault. I would be grateful if you could help me.
