How can I debug my Qt software on the Mini2440 (while its actually running on the Mini2440)? I cant use an emulator because I have custom hardware attached to the Mini2440 which must be included in the debug process. Will I have to install Qt on the Mini2440 itself to accomplish this or is there a different method? Currently I'm either executing my Qt software from the SD card or over ethernet.
Debug QT software running on Mini2440
If you have a copy of your target's root filesystem on your host (which includes the debug info at the host side), you can use a remote-debug session on your Mini2440 while the debugger app is running on your host and connected to the Mini2440 via network.
Hi Juergen, Thank, that sounds like it could be my solution Do you know where I can find the Qt GDB file for the ARM (mini2440) generated by PTX? MC
Currently I'm pointing to: /opt/OSELAS.Toolchain-2011.03.0/arm-v4t-linux-gnueabi/gcc-4.5.2-glibc-2.13-binut ils-2.21-kernel-2.6.36-sanitized/bin Is this correct? Or should I point to the one in the target build?
The host part of the compiler is located in the OSELAS.Toolchain. The target part is in your local project if you enable it (and transferred it to the target. I would recommend NFS root). On the target then run: mini2440> gdbserver <host-ip>:<port> <your-program-to-debug> Then start the GDB on your host (from inside the BSP project): /opt/OSELAS.[...]/bin/arm-v4t-linux-gnueabi-gdbtui platform-mini2440/root-debug/<your-program-to-debug> Tell GDB where to search for the run-time debug info: (gdb) set solib-absolute-prefix platform-mini2440/root-debug (gdb) target remote <target-ip>:<port> After that you can use all the known GDB commands. Note: The debug info is not required at the target's side. But an exact local copy with all debug info must be present at the host to make GDB work. That's why PTXdist provides you the 'root/' and the 'root-debug/' directory. Both are exactly the same, but the 'root-debug/' still contains all debug info. That's also why I recommend to use NFS root, to ensure the binaries are always the same in both "worlds" (the target can still mount 'root/' as its root filesystem, because it does not need the debug info, only GDB must be pointed to the 'root-debug' directory).
I don't know. This old Qt creator is going to drive me insane. I'm busy installing Ubuntu 12 with the new Qt creator. There seems to much more information on creating a remote debug session using the new Qt creator.
Yes, I'm running Mini2440 from NFS. So basically Mini2440 is actually executed from the host over NFS. Then at the same time I do a remote debug session also over ethernet. This does not make sense. Why would I want to run Mini2440 over NFS and then do remote debugging. What I'm trying to say is, if the Mini2440 is already executed on the host via NFS then there is no need to do remote debugging. I can then just do local debugging since the Mini2440 will manipulate the files on the host since it is being executed from the host. Hope you get what I'm trying to say.
NFS is for convinience only. When the code is running on the Mini2440 also the debugger must be "present" on the Mini240. For example each breakpoint must be set on the Mini2440 (in its local RAM), even if the code was loaded via NFS from your host.
