export command for arm-linux-gcc
xycoder
i downloaded arm-linux-gcc-4.4.3 and install it to /home/armgcc on fedora 9
then i type the command $ export PATH=$PATH:/home/armgcc/..../bin
and "arm-linux-gcc  -v" show me the version of the compiler
but when i closed the terminal and then again open i type the command
"arm-linux-gcc -v"
this shows me a "bash:....not a command"
why i have to type again $ export PATH=$PATH:/home/armgcc/...../bin
everytime when i open the terminal ??
regards
Juergen Beisert
Run "man bash", search for the 'export' keyword and read how environment
variable inheritance is really working in Bash.
After that I'm sure you will add this export command into your local
~/.bashrc or the global /etc/bashrc (or whatever shell you are using).
