Am I really the only one having this problem? Buserror's 2.6.32 kernel correctly displays full size images on essentially all of the screens shipped with the Mini2440. I moved up to 3.1.4 just to get up to date. But now the image only occupies the upper left quarter of the screen. It's as if the linear dimensions have been cut in half (or doubled, depending on how you want to look at it). I've updated mach-mini2440.c with the Pengutronix patches to support all displays. But I don't think this problem is in that file. I diff'ed s3c2410fb.c between 2.6.32 and 3.1.4 and don't see anything suspicious there. Any ideas? Thanks, Doug
Mini2440 display resolution
What application is generating the images? Qt? Are you setting any environment variables for use with Qt? Dave
