I have recently bought Tiny 6410 with 3" LCD, the problem is when I run Android on it the screen resolution get messed up...its like when one dosent have the VGA driver...If i run linux, then it works perfectly...then screen resolution and video resolution both work great. Help Please..
Bad Resolution
You need to select the correct kernel in the friendlyarm.ini file. In the section of the script for Android, make sure it is the w35 or x35 (or whatever 3.5" you have) kernel. Just change the suffix of the file.
