Hello All, I have just compile 2.6.33 kernel using RT patch 2.6.33-Test #16 PREEMPT RT Mon Dec 19 14:49:30 IST 2011 armv4tl unknown and successfully ported to board, but when i type any command such as 'ls' it respond too slow, do i need to compile whole file system using rtapi ? or just rt kernel is OKay? I am trying to get max. freq on gpio pin. please suggess a solution why console respond too slow after upgrading board to new kernel. Thank you for your time in advance. -- miniarm
2.6.33 kernel
Take a look into "/proc/interrupts". When I tried the RT patch the last time the serial driver went amok and created about 500,000 interrupts per char. And: the S3C2440 CPU has a timer with only 16 bit width. There is no HRT driver present for this timer (AFAIK). So, RT Preempt will not run as expected on this CPU.
Hello Juergen, Some developer is saying that rt kernel won't work with mini2440, is that true? if so then what is the solution for this problem? I want to get maximum freq. from the gpio pin. when i try to read the pin, read system call takes maximum time, so i thought if i use rt kernel that will solve the problem. Plz help. --miniarm
if you want max. speed driving a GPIO (PWM?) in software, you shouldn't use a operating system like Linux or something similar. Driving a GPIO with high frequency in software is a really bad idea.
Dear Andre, http://www.friendlyarm.net/forum/topic/3476, people are saying here that they have got freq. above 400 khz using pwm, that's why i am trying to achieve at-least 800 khz instead of 382 khz. your help or guidance will be much appreciated. regards, miniarm
finally successfully ported 2.6.39 kernel to board, and compiled mini2440_pwm.c program as a module, load to kernel, when try to run pwm_test program it gives increment in freq. but buzzer is not working, However if i export pin to /sys/gpio interface and add value 1 to 'value' parameter, buzzer is working perfectly. what could be the change? what i am missing here? why buzzer is not working with .39 kernel, have you encounter the same problem? Please let me know. -- miniarm
Hello Finally successfully installed and run 2.6.39 kernel into the board with yaffs2 file system, system is running perfectly fine, also solved the problem of buzzer, ( the new kernel comes with different syntax of ioctl ), but still not able to get good freq. real 0m 2.20s user 0m 0.70s sys 0m 1.50s Here are the reading for running a c program that drive the motor 10 times, in 2.6.32 kernel total time was 1.91s, but after upgrading kernel it is 2.20s. don't know why, what could be the proble? @Andre, can you please help me out there? -- miniarm
