I bought a cam130 but I don't get work camera. I read some topic in forum. l try this code but I don't understand. I use QT Creator and ı set up kernel and root file system. now I am able to control led button and buzzer. I need some document and code I tried some code. example: ioctl( fd, VIDIOCSYNC, &frame ); memcpy(img.bits(),frames + mbuf.offsets[frame], width * heigh * 4); I don't know this codes. memcpy ? vıdıocsync? if you give path and information. I am very happy.
camera mini2440 some problem
try example friendly arm test code. I tried it. you should read camera driver. you try and work...:)
