SMTP CONFIGURATION IN MINI2440
VENKAT
I WANT TO SEND MAIL FROM MY DEVICE.
HOW TO CONFIGURE IN MINI2440
Save the capitals for emphasis.
You will need to run an smtp client on the machine.  I use msmtp
stand-alone, although msmtp with Mutt is a commonly used program.
The instructions on the msmtp homepage are quite straight-forward.
Authentication may be the most difficult part, if needed.
Sushant
hello,
i currently used smtp its work fine on laptop but its not work on mini2440.
   Smtp* smtp = new Smtp(ui->uname->text(), ui->paswd->text(),
ui->server->text(), ui->port->text().toInt());
in memory allocation time its show Illegal instruction
why this error occured
Sandeep Sondagar
"Illegal Instruction" error Occurs when you Compile code for one processor
architecture and Try to run that binary on processor with different
architecture.
i.e. wrong "-march=" option
Sushant
Hello Sandeep Sondagar,
Thanx
I use this
QMAKE_CFLAGS_RELEASE += -march=armv4 -mtune=arm920t
QMAKE_CFLAGS_DEBUG += -march=armv4t -mtune=arm920t
QMAKE_CFLAGS_MT += -march=armv4t -mtune=arm920t
QMAKE_CFLAGS_MT_DBG += -march=armv4t -mtune=arm920t
QMAKE_CFLAGS_MT_DLL += -march=armv4t -mtune=arm920t
QMAKE_CFLAGS_MT_DLLDBG += -march=armv4t -mtune=arm920t
QMAKE_CFLAGS_SHLIB += -march=armv4t -mtune=arm920t
QMAKE_CFLAGS_THREAD += -march=armv4t -mtune=arm920t
QMAKE_CFLAGS_WARN_OFF += -march=armv4t -mtune=arm920t
QMAKE_CFLAGS_WARN_ON += -march=armv4t -mtune=arm920t
QMAKE_CXXFLAGS_DEBUG += -march=armv4t -mtune=arm920t
QMAKE_CXXFLAGS_MT += -march=armv4t -mtune=arm920t
QMAKE_CXXFLAGS_MT_DBG += -march=armv4t -mtune=arm920t
QMAKE_CXXFLAGS_MT_DLL += -march=armv4t -mtune=arm920t
QMAKE_CXXFLAGS_MT_DLLDBG += -march=armv4t -mtune=arm920t
QMAKE_CXXFLAGS_RELEASE += -march=armv4t -mtune=arm920t
QMAKE_CXXFLAGS_SHLIB += -march=armv4t -mtune=arm920t
QMAKE_CXXFLAGS_THREAD += -march=armv4t -mtune=arm920t
QMAKE_CXXFLAGS_WARN_OFF += -march=armv4t -mtune=arm920t
./configure -embedded arm -xplatform qws/linux-arm-g++ -prefix
/usr/local/Qt -qt-mouse-tslib -little-endian -no-webkit -no-qt3support
-no-cups -no-largefile -optimized-qmake -openssl -L/PATH/Lib
-I/PATH/include/ -nomake tools -qt-sql-sqlite -no-3dnow -system-zlib
-qt-gif -qt-libtiff -qt-libpng -qt-libmng -qt-libjpeg -no-opengl -gtkstyle
-no-openvg -no-xshape -no-xsync -no-xrandr -qt-freetype -qt-gfx-linuxfb
-qt-kbd-tty -qt-kbd-linuxinput  -qt-mouse-tslib -qt-mouse-linuxinput
Sushant
my working Qt configuration is
-no-cups -no-largefile -optimized-qmake -no-openssl -nomake tools
-qt-sql-sqlite -no-3dnow -system-zlib -qt-gif -qt-libtiff -qt-libpng
-qt-libmng -qt-libjpeg -no-opengl -gtkstyle -no-openvg -no-xshape -no-xsync
-no-xrandr -qt-freetype -qt-gfx-linuxfb -qt-kbd-tty -qt-kbd-linuxinput
in this configuration i am not use openssl last time.
Send me the solution
