Design PCB Tiny6410
khaclub
I'm a student & I have board Tiny6410 1111 and intend to design a clone of
it. I've already boot Android/WinCE/Ubuntu/Linux in Tiny6410.
I have some questions to understand the code of OS. My clone board has just
some components :
S1 , S2
CN1
U5 : Replaced with LM1117S-3.3V
R11,R41 , R2 , R21 R22 , R16 R17 R79 R80
C1 ,C2 C3 C62 C69 C70 C71 C72
LED_3.3
RST
LCD2
P1,P2
- What is my problem ?
When I switch S2 to SD mode & insert SD card , all the off leds seems to be
in SD boot state.
When I switch S2 to Nand mode (with any included modified OS of
FriendlyARM) , LED1 blink. I read the manual & it said that the board is in
the boot state. When I solder U1 (MAX3232CDR) to debug, in Nand MODE , LED1
off , in UART app bit CD on off continuously . I turn on bit DTR => LED1
blinky forever, no output data from COM0
My schematic is the same as Tiny6410 1111.
- My questions :
  + Can my board with components like that RUN any FriendlyARM OS ?
  + What components will be checked when the CORE start ? I mean, because
in Nand mode LED1 blink , so I think the CORE probably wait to receive ACK
from some components that I don't know.
The OS code is so large for me to take alot of time to understand & modify.
Can someone help me ? Thanks
Dave McLaughlin
Hi there,
Does you board include the boot loader?
Dave...
khaclub
Yes, the CORE 6410 has already been installed when it plugged in KIT
Tiny6410
khaclub
Hix, no one help me ?
mindee
Hi, khaclub
see here: http://www.arm9home.net/read.php?tid-15548.html
khaclub
Thank you very much. It's very good stuff
ISDiniz
Hi khaclub
I have the problem.
Can you send the schematic? Thanks
