Change gpio pin value during kernel boot
eduardo
Micro2440 sets some GPIO pins with 3v3 during the kernel boot. When linux
starts, my application set those pins to 0.
Now, I need to change one of these pins to 0v during kernel boot, before
the system start up.
I already knows how to control GPIO pin, but I don't which file is
responsible for the sequence of commands executed during the boot.
Anyone knows where could I find some useful information?
Thanks in advance
I change my GPIO pins in /etc/profile.environment.  However, I am using the
Pengutronix BSP.
From memory, for the FriendlyArm distros try /etc/rcS or somewhere in
/etc/init.d
eduardo
Hi Dave,
Thanks for your fast reply :D
When rcS starts it's too late. I need to set those pins even before that.
I think I'll need to change some source file from kernel (and compile it
again)...
Andre
Hi Eduardo, I have the same problem with Microcontrollers, I think is a
hardware problem rather than a software, everytime I start a pic or atmel
even if I set the pins low they go high,
eduardo,
Sorry, didn't see words "before the system starts".  As a hardware
work-around, maybe try inverting that output with an external transistor
and then invert the logic for that GPIO.  However, there might be a short
period where that pin would be incorrect, ie between kernel initialisation
and when you could change it in /etc/rcS.
Good luck!
Dave
Dave McLaughlin
Hi Andre,
This is normal for microcontrollers like the PIC and Atmel. The ports are
usually set to input with a weak pullup.
If you need it low on power up and before your application has started, you
can fit a pull down resistor on the IO Pin. Some microcontrollers will be
LOW state. Consulting the datasheet will let you know.
I have had to do this with the Mini6410 for the power supply to stay on. I
am working on this pin powering down the device under software control.
It's default state is LOW and an input and I need it HIGH so I installed a
pullup.
Dave...
Juergen Beisert
eduardo, you can change the GPIO settings in the u-boot bootloader or in
the Linux kernel in the platform file
(arch/arm/mach-s3c2440/mach-mini2440.c).
eduardo
Thanks for all responses. I don't want to change hardware stuff... I'll try
to find a software solution.
Yesterday I changed the file
"linux-2.6.32.2/arch/arm/mach-s3c2440/mach-mini2440.c", and I saw that I
can control those pins. With a multimeter I saw the pin with 3v3 when I
turn on the board, half second later, the pin was down to 0v (that was my
modification), and half second later it become 3v3 again. I'll try to find
which code was responsible for turn the pin 3v3 again after my
modification...  xD
I'll try it for today. If all go wrong, I'll follow the hardware
suggestion. ;)
Thanks again
eduardo
Hi Juergen,
Thanks for your reply. I saw it just after post my last reply.
I changed the mach-mini2440.c file, and it works (pin goes 0v), but there's
another function that turn on the pin with 3v3 again (I don't know where,
but with a multimeter I can see that it happens).
I'll look for the settings on uboot bootloader. :)
Thanks for the suggestion.
Juergen Beisert
If there is somebody who change the GPIO state after the platform file has
initialized them, you also have no chance with a modified bootloader. I
guess the GPIO you are using is used by a different driver for one of the
devices in the S3C2440 CPU.
You should take a closer look to the source if this GPIO pin is feed into a
different driver via the corresponding platform_data structure (for example
the SD/MM driver receives GPIO definitions for the "change detect" and
"write protect" signals).
You should lock your GPIO pin with the gpio_request() function. In this
case someone other will be rejected to use the same pin again.
The best place to request a GPIO is again the platform file for the
Mini2440 (arch/arm/mach-s3c2440/mach-mini2440.c).
eduardo
Hi Juergen,
Thanks for your response. You are fully corret. Searching for uses of the
GPIO constant, I found it on the camera driver. I'm not using this driver,
so I cut off this driver of my kernel. The
"arch/arm/mach-s3c2440/mach-mini2440.c" file was already changed and
everything work like excpected.
The problem is solved, thanks for all the help.
adavappa
Hi I am having the similar problem ,
I am using the Imx53 board. When start only u--boot LED's will be in OFF
state(GPIO - Active low).When kernel boots up those LED's will change the
state to ON (GPIO - Active high). I am not able to trace who is setting
this GPIOS values high in kernel code , if any one faced same issue, please
let me know .
Thanks,
Adavappa
androjes
What I need to change on
"linux-2.6.32.2/arch/arm/mach-s3c2440/mach-mini2440.c" to active pullup on
GPIO?
