I've prepared Eclipse to compile Qt programs for mini2440 friendly-arm board. I compiled a sample program successfully. But when I want to debug it remotely I get this error: >Error during file upload. Failed to connect sshd on "192.168.1.230:22" My connection is connected successfully and I can ping 192.168.1.230 but I can't run and debug a program remotely with it. Would somebody help me?
Remote Debugging with Eclipse
hello qdeveloper, if you have a solution, please publish it. Because i have the same problem. How do you make the connection between your Linux-PC and your mini2440? Do you use gdb-srv (which version) or a other debugging tool? Which tuning / parameter you use in eclipse|project|debug? best wishes
If somebody knows how to set Eclipse to arm-linux-gcc 4.3.2 and to debug remotely will be very useful. Also some links which can be provided
Maybe you can look at http://www.armbedded.eu/node/208 I hope this will help you
