Hi ARM friends, I have a linux system on my mini2440 with images provided on DVD. I am trying to insert "mini2440_hello_module.ko" module which sources are available also on DVD. I am struggling with two problems: 1.after inserting nothing is printed in console window, I expect "Hello, Mini2440 module is installed", 2.I can not remove the module. see below: [root@FriendlyARM plg]# ls mini2440_hello_module.ko [root@FriendlyARM plg]# insmod mini2440_hello_module.ko [root@FriendlyARM plg]# lsmod mini2440_hello_module 564 0 - Live 0xbf000000 [root@FriendlyARM plg]# rmmod mini2440_hello_module.ko [root@FriendlyARM plg]# lsmod mini2440_hello_module 564 0 - Live 0xbf000000 I will appreciate any help, thanks
Problem with removing module - rmmod
Hi, thanks Juergen, this is really weird, but works, have a look: [root@FriendlyARM plg]# insmod mini2440_hello_module.ko [root@FriendlyARM plg]# lsmod mini2440_hello_module 564 0 - Live 0xbf000000 [root@FriendlyARM plg]# rmmod "mini2440_hello_module" rmmod: module 'mini2440_hello_module' not found [root@FriendlyARM plg]# lsmod [root@FriendlyARM plg]#
