Clear the environment settings ?
Ben
whenI use printenv at the uboot mini2440 prompt I get a LOT of settings.
What is the way to start with a clean list ?
See pasted text below:
MINI2440 # printenv
bootdelay=3
baudrate=115200
ethaddr=08:08:11:18:12:27
ipaddr=10.0.0.111
serverip=10.0.0.4
netmask=255.255.255.0
usbtty=cdc_acm
mini2440=mini2440=0tb
bootargs_init=init=/sbin/init
root_nfs=/mnt/nfs
ifconfig=ip=dhcp
${mini2440} ${root_mmc}
${mini2440} ${root_nand}
mtdids=nand0=mini2440-nand
mtdparts=mtdparts=mini2440-nand:0x00040000(u-boot),0x00020000(u-boot_env),0x0050
0000(kernel),0x3faa0000(rootfs)
bootcmd=mmcinit ; ext2lÏad mmc 0:2 0x31000000 uImage ; bootm 0x31000000
bootargs=console=ttySAC0,115200 noinitrd root=/dev/mtcblk0p2 rootwait=4 rw
ip=dhcp init=/bin/sh
partition=nand0,0
mtddevnum=0
mtddevname=u-boot
Environment size: 1215/131068 bytes
<uboot commands reference>
http://www.google.co.nz/#sclient=psy-ab&hl=en&source=hp&q=ub...
couldn't see any in LITE5200BUBPG.pdf
Ben
Tnx for your reply, Dave.
I have been at the Uboot page and did find one way to clear settings , it
is "setenv name" without entering a value. I did this about 25 times and
now only the baudrate is set.
Starting with cleared environment now, trying to get debian to boot from
SD.
Kind regards,
Ben
Ben,
Actually. I saw that as well but thought it was a pretty "long-winded" way
of achieving a simple task!
Dave
