Hi all, I have compiled Qt4.7.4 and installed it on my mini2440. When I run the refreshtest example I have 16 Fps. With the 6.3 libs this was 31 Fps. The oscilloscope example is very very slow ... Is the a way to optimize this or do I have to use the Qt6.3 libs ? When I run ts_calibrate the console shows the message : selected device is not a touchscreen I understand Altough the touchscreen works on all Qt-applications ! the Qt calibrate example does not work as well The only way to calibrate my touchscreen is to launch it from qtopia. Any idea ?
