Dear Troubleshooters, I want to establish SNTP client on mini2440 system for clock synchronisation with the SNTP server on windows XP. Can any one of you suggest me this HOW2? With best regards, nikhil@amitech.in
Use a cross build system to build your root filesystem and you just have to enable an SNTP client to make it work.
Dear trouble shooter, I have crosse compiled the ntp source with the arm-linux-gcc tool chain and generated ntpd,ntpdate etc binaries. My problem is when i entered the following command, #ntpdate 192.168.1.204 comment(ntp-server windows) 24 Nov 17:29:35 ntpdate[833]: adjust time server 192.168.1.204 offset -0.243537 sec #date Thu Nov 24 17:33:38 CST 2011 which is incorrect. My ntp-server is on Windows and client on friendly arm, which share a common LAN. I shall be thank full for your valuable suggestion. With best regards, nikhil@amitech.in
