Hello, I installed arm-gcc-4.4.3 from FriendlyARM (in opt/FriendlyARM/) I set the variable with #export PATH=$PATH:/opt/FriendlyARM/toolschain/4.4.3/bin I tested with the command #arm-linux-gcc -v And it's working!! But when I try to compile android sources (from FriendlyARM), the command make menuconfig return me: HOSTCC scripts/basic/fixdep /bin/sh: gcc: not found make[1]: *** [scripts/basic/fixdep] Erreur 127 make: *** [scripts_basic] Erreur 2 Like it try to use the GCC from my distrib instead of arm-gcc Is there another step I forget to install arm-gcc?? thanks for help
arm-gcc correctly installed but can't use it!!
the problem is before the compile! #make menuconfig return me a error /bin/sh: gcc: not found like it can't find the arm-linux-gcc compiler!!! But I tested to compile a simple hello world example with the following command: #arm-linux-gcc -o hello hello.c I works!!
But you said: ********* But when I try to compile android sources (from FriendlyARM), the command make menuconfig return me: HOSTCC scripts/basic/fixdep /bin/sh: gcc: not found make[1]: *** [scripts/basic/fixdep] Erreur 127 make: *** [scripts_basic] Erreur 2 ********* How are you setting up your cross-compile environment variables? For example: export CROSS_COMPILE= arm-none-linux-gnueabi- export CC="${CROSS_COMPILE}gcc -march=armv4t -mtune=arm920t etc etc Is this for the mini2440 or mini6410? Could you link to the tutorial you are using?
I follow this tutorial http://my.opera.com/vinodmunikoti/blog/manual-for-compiling-android-for-... It supposed to be the translation of this one: http://www.friendlyarm.net/dl.php?file=android-guide.pdf and no, I didn't setting up the cross-compile variables! The tutorial or topics on this forums don't talk about this. This is for a mini2440 with a display W35
Well, it looks like you don't need to set any of them. Perhaps in the configuration file used. However, if you get it to compile you may have another problem . . . your display type. Is W35 supported by this procedure?
shame on me! the make menuconfig need the GCC (not arm-linux-gcc), so a simple #aptitude install gcc solve my problem about the display, I know there is modifications to do in the friendlyArm android archive. I guess this is not a big problem, I found a tutorial to do it.
