Use Keil ULINK2 for Debug with S3C2440A
Sujit Yardi
we want to use ULINK 2 to debug S3C2440A device , However we are unable to
detect the hardware in Keil 4.0 IDE Evaluation version. After going through
connector details we found that RTCK Pin is not present in S3C2440A So I
would like to know the Detail Connection diagram required for ULINK 2 with
S3C2440A which will enable me to debug S3C2440A.
Nilson
Hello Sujit Yardi!
I got hold of Mini2440 debugging with Keil and ULINK2. I cut the flat cable
10 pins Mini2440 and cut the ribbon cable 20 pin ULINK2 Deois and amended
the following sequence:
Mini2440 10 pin header               Signal          ARM 20 Pin header
1,2                     VDD33V <--> VTref, Vsupply       1,2
3                       TRST <--> nTRST                 3
4                      RESET <--> nSRST                15
5                        TDI <--> TDI                 5
6                        TDO <--> TDO                13
7                        TMS <--> TMS                 7
9                        TCK <--> TCK                 9
8, 10                        GND <--> GND    4,6,8,10,12,14,16,18,20
No connection                    RTCK  11
No connection                    DBRQ  17
No connection                   DBGACK  19
If it works let me know: nilsao@gmail.com
Dani Konoplya
Can somebody please add a pictture of properly connection mini2240 to
ULINK2 and to Keil 4.0 IDE.It will very help and easy to understand.
Dani Konoplya
Can somebody please add a picture of properly connection mini2440 S3C2440A
device to
