Hello, I have MINI2440. After successfully compiled hello example with arm-linux-gcc 4.4.3, I try to execute the binary on the board, but i get the following: [root@FriendlyARM /]# ls -la /home/jmanous/ drwxr-sr-x 1 jmanous 503 512 Jan 1 00:09 . drwxr-xr-x 1 root root 512 Jun 26 2007 .. -rw-r--r-- 1 jmanous 503 355 Jan 1 1970 .ash_history -rwxrwxrwx 1 jmanous 503 47126 Jan 1 1970 bzip2_1.0.5-1+lenny1_arm.deb -rwxrwxrwx 1 jmanous 503 7860 Jan 1 00:07 hello [root@FriendlyARM jmanous]# ./hello -sh: ./hello: not found Any Ideas? Thank You, John.
Run it in the following way: [root@FriendlyARM jmanous]# LD_DEBUG=libs ./hello It should show you what shared libraries it wants to use. Maybe some are missing in your system.
Thank you for your reply. Unfortunately the output was identical. [root@FriendlyARM jmanous]# LD_DEBUG=libs ./hello -sh: ./hello: not found I am wondering what could it be, a binary or a compiler problem? Thank You, John
Try to dump your hello file and post the output here: arm-linux-objdump -x ./hello ( in your host PC)
Hello, Thank you all for your suggestions, I just figured out that file outputs: /home/jmanous/ARM/examples/hello # file hello hello: ELF 32-bit LSB executable, ARM, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.14, stripped I run 2.6.13 :| But is that really the case? And if so, is there any possibility to configure gcc to output executables for older versions? Hexdump produces the following: ./hello: file format elf32-littlearm ./hello architecture: arm, flags 0x00000112: EXEC_P, HAS_SYMS, D_PAGED start address 0x000082c8 Program Header: 0x70000001 off 0x0000043c vaddr 0x0000843c paddr 0x0000843c align 2**2 filesz 0x00000008 memsz 0x00000008 flags r-- PHDR off 0x00000034 vaddr 0x00008034 paddr 0x00008034 align 2**2 filesz 0x00000100 memsz 0x00000100 flags r-x INTERP off 0x00000134 vaddr 0x00008134 paddr 0x00008134 align 2**0 filesz 0x00000013 memsz 0x00000013 flags r-- LOAD off 0x00000000 vaddr 0x00008000 paddr 0x00008000 align 2**15 filesz 0x00000448 memsz 0x00000448 flags r-x LOAD off 0x00000448 vaddr 0x00010448 paddr 0x00010448 align 2**15 filesz 0x0000011c memsz 0x00000120 flags rw- DYNAMIC off 0x00000454 vaddr 0x00010454 paddr 0x00010454 align 2**2 filesz 0x000000e8 memsz 0x000000e8 flags rw- NOTE off 0x00000148 vaddr 0x00008148 paddr 0x00008148 align 2**2 filesz 0x00000020 memsz 0x00000020 flags r-- STACK off 0x00000000 vaddr 0x00000000 paddr 0x00000000 align 2**2 filesz 0x00000000 memsz 0x00000000 flags rw- Dynamic Section: NEEDED libc.so.6 INIT 0x8274 FINI 0x8418 INIT_ARRAY 0x10448 INIT_ARRAYSZ 0x4 FINI_ARRAY 0x1044c FINI_ARRAYSZ 0x4 HASH 0x8168 STRTAB 0x81e0 SYMTAB 0x8190 STRSZ 0x41 SYMENT 0x10 DEBUG 0x0 PLTGOT 0x1053c PLTRELSZ 0x20 PLTREL 0x11 JMPREL 0x8254 REL 0x824c RELSZ 0x8 RELENT 0x8 VERNEED 0x822c VERNEEDNUM 0x1 VERSYM 0x8222 Version References: required from libc.so.6: 0x0d696914 0x00 02 GLIBC_2.4 private flags = 5000002: [Version5 EABI] [has entry point] Sections: Idx Name Size VMA LMA File off Algn 0 .interp 00000013 00008134 00008134 00000134 2**0 CONTENTS, ALLOC, LOAD, READONLY, DATA 1 .note.ABI-tag 00000020 00008148 00008148 00000148 2**2 CONTENTS, ALLOC, LOAD, READONLY, DATA, LINK_ONCE_DISCARD 2 .hash 00000028 00008168 00008168 00000168 2**2 CONTENTS, ALLOC, LOAD, READONLY, DATA 3 .dynsym 00000050 00008190 00008190 00000190 2**2 CONTENTS, ALLOC, LOAD, READONLY, DATA 4 .dynstr 00000041 000081e0 000081e0 000001e0 2**0 CONTENTS, ALLOC, LOAD, READONLY, DATA 5 .gnu.version 0000000a 00008222 00008222 00000222 2**1 CONTENTS, ALLOC, LOAD, READONLY, DATA 6 .gnu.version_r 00000020 0000822c 0000822c 0000022c 2**2 CONTENTS, ALLOC, LOAD, READONLY, DATA 7 .rel.dyn 00000008 0000824c 0000824c 0000024c 2**2 CONTENTS, ALLOC, LOAD, READONLY, DATA 8 .rel.plt 00000020 00008254 00008254 00000254 2**2 CONTENTS, ALLOC, LOAD, READONLY, DATA 9 .init 00000010 00008274 00008274 00000274 2**2 CONTENTS, ALLOC, LOAD, READONLY, CODE 10 .plt 00000044 00008284 00008284 00000284 2**2 CONTENTS, ALLOC, LOAD, READONLY, CODE 11 .text 00000150 000082c8 000082c8 000002c8 2**2 CONTENTS, ALLOC, LOAD, READONLY, CODE 12 .fini 0000000c 00008418 00008418 00000418 2**2 CONTENTS, ALLOC, LOAD, READONLY, CODE 13 .rodata 00000018 00008424 00008424 00000424 2**2 CONTENTS, ALLOC, LOAD, READONLY, DATA 14 .ARM.exidx 00000008 0000843c 0000843c 0000043c 2**2 CONTENTS, ALLOC, LOAD, READONLY, DATA 15 .eh_frame 00000004 00008444 00008444 00000444 2**2 CONTENTS, ALLOC, LOAD, READONLY, DATA 16 .init_array 00000004 00010448 00010448 00000448 2**2 CONTENTS, ALLOC, LOAD, DATA 17 .fini_array 00000004 0001044c 0001044c 0000044c 2**2 CONTENTS, ALLOC, LOAD, DATA 18 .jcr 00000004 00010450 00010450 00000450 2**2 CONTENTS, ALLOC, LOAD, DATA 19 .dynamic 000000e8 00010454 00010454 00000454 2**2 CONTENTS, ALLOC, LOAD, DATA 20 .got 00000020 0001053c 0001053c 0000053c 2**2 CONTENTS, ALLOC, LOAD, DATA 21 .data 00000008 0001055c 0001055c 0000055c 2**2 CONTENTS, ALLOC, LOAD, DATA 22 .bss 00000004 00010564 00010564 00000564 2**0 ALLOC 23 .comment 0000002a 00000000 00000000 00000564 2**0 CONTENTS, READONLY 24 .ARM.attributes 00000028 00000000 00000000 0000058e 2**0 CONTENTS, READONLY SYMBOL TABLE: no symbols Thank you again, John
Hello again, I have found the solution. Since I am using an ancient kernel version, I tried the also ancient gcc-3.3.2 and everything was fine. This version can produce executables for kernel 2.0.0 and up. Thank you for pointing to the right direction. Sincerely, John
Because the setup was fast (this kernel was the newest supplied with the dvd back in 2009). Newest kernels for mini2440 from here/downloads do not just boot when I download them with the bootloader in NOR flash (they need to be configured properly I guess). Sincerely, John
compile hello program with --static option Ex: #arm-linux-gcc-4.4.3 hello.c --static -o hello Happy knowledge sharing :-)
