Hello everyone ! I have just purchased mini2440 for my project work. I am average linux user and have some command-line experience. I have compiled and run the some examples successfully. but came to know that GPIO doesn't appear in shipped linux. So, i recompiled linux kernal image with help of following site : http://members.cox.net/ebrombaugh1/embedded/mini2440/index.html after loading zImage to nor flash i can see drivers of GPIO in '/sys/class/' but my problem is with screen. the screen is shifted after image upadate. i can not able to operate terminal or calibate application. what i have to do now ? Please help. Thanks in advance.
Screen Calibration after new kernal image
Are you using the correct config? cp config_mini2440_t35 .config # choose the pre-built config that matches your LCD What LCD does your mini2440 use? Or search for "shifted screen", I recall a few posts about this issue. Can you enter a command like: find -name ts_calibrate -print and tell us what is says?
Sorry, no on-screen terminal! Can you run minicom on your host and via RS232 enter the command suggested?
hi davef I am using W35 Lcd. i compiled the kernel that came with kit.i didnt make any changes. currently i doesn't have the 2440.but, i will reply for your suggested in few hours. yes, minicom is running in terminal on windows and also ftp is running. from one site i came to find i could attech mouse at boot time and open calibrate in tools than issue can be fixed. is this will work ? or i have recompile the kernal ?
from one site i came to find i could attech mouse at boot time and open calibrate in tools than issue can be fixed. is this will work ? or i have recompile the kernal ? Sorry, I don't understand what you are saying. Is there a W35 config file in the distribution?
hello davef. No, the mouse trick dosnt work. Thanks for remind me for config file. i atteched wrong file (for t35 with gpio and spi support). i followed this steps which then worked. #in linux kernel directory jaydeep@ubuntu:~$ make clean jaydeep@ubuntu:~$ cp config_mini2440_w35 .config jaydeep@ubuntu:~$ make menuconfig #in menuconfig enable gpio and spi support jaydeep@ubuntu:~$ make zImage Thanks again davef.
hello sir: i'm a new user for arm mini2440. already preloaded qtopia. in that i click re-calibarate. then its restart. then touch screen not working. what can i enter it's show enter your password i already set pwd. how to work my touch screen please explain me
Sometimes the screen calibration can be so bad that you can not control the cursor or get the cursor on-screen. In this case, attach a generic USB mouse and reset. The cursor will move from both mouse and touch pad. Go to the "Tools" tab in Qtopia and start recalibration. Just use a mouse click when it wants you to tap the screen to run the app. Use a stylus on the touch pad (not the mouse!) to get calibration back in range.
