Hi, I've just purchased a Tiny6410SDK with N43. I've built a 4GB SDK with the provided SD Flasher and the "images" directory on the SD2, with no problems. However, most OSs fail to run or install. If I try installing the OSs on the NAND Flash, WindowsCE6 works (althrough it's in Chinese, and I don't know how to put it in English), but all Android, Linux and Ubuntu fail. They install correctly, but fail to run. On my serial terminal, I see all kinds of kernel panics, etc, on all of them (I can provide logs if necesary). If I try running the OSs from the SD card, WindowsCE6 runs, and this time Linux runs as well. Ubuntu still fails, and Android fails, but this time at least, instead of kernel panicking, it shows the boot logo, but halts there, and shows some errors, like: -------------------- mount: mounting /sdcard on /r/sdcard failed: No such file or directory init: cannot open '/initlogo.rle' init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instea d. enabling adb adb_open / # Compat-wireless backport release: compat-wireless-2011-06-28-2-FA Backport based on linux-next.git next-20110707 cfg80211: Calling CRDA to update world regulatory domain libertas_sdio: Libertas SDIO driver libertas_sdio: Copyright Pierre Ossman usbcore: registered new interface driver ath9k_htc usbcore: registered new interface driver rt73usb usbcore: registered new interface driver rt2800usb rtw driver version=v3.0.1590.20110511 usbcore: registered new interface driver rtl8192cu usbcore: registered new interface driver zd1211rw warning: `zygote' uses 32-bit capabilities (legacy support in use) s3c-rtc s3c64xx-rtc: rtc only supports 100 years alarm_set_rtc: Failed to set RTC, time will be lost on reboot request_suspend_state: wakeup (3->0) at 45771647024 (1970-01-02 00:00:11.0877378 50 UTC) init: untracked pid 1133 exited init: untracked pid 1126 exited ------------[ cut here ]------------ WARNING: at kernel/mutex-debug.c:78 debug_mutex_unlock+0xac/0x118() Modules linked in: zd1211rw rtl8192cu rt2800usb rt2800lib rt73usb rt2x00usb rt2x 00lib ath9k_htc ath9k_common mac80211 ath9k_hw ath libertas_sdio libertas cfg802 11 compat [<c016a9a4>] (unwind_backtrace+0x0/0xe4) from [<c017f51c>] (warn_slowpath_common +0x4c/0x64) [<c017f51c>] (warn_slowpath_common+0x4c/0x64) from [<c017f54c>] (warn_slowpath_n ull+0x18/0x1c) [<c017f54c>] (warn_slowpath_null+0x18/0x1c) from [<c01a596c>] (debug_mutex_unloc k+0xac/0x118) [<c01a596c>] (debug_mutex_unlock+0xac/0x118) from [<c050c530>] (__mutex_unlock_s lowpath+0xb4/0x110) [<c050c530>] (__mutex_unlock_slowpath+0xb4/0x110) from [<c0422af0>] (s3c_g3d_ioc tl+0x158/0x270) [<c0422af0>] (s3c_g3d_ioctl+0x158/0x270) from [<c0422c58>] (s3c_g3d_release+0x50 /0x64) [<c0422c58>] (s3c_g3d_release+0x50/0x64) from [<c01e796c>] (fput+0x114/0x210) [<c01e796c>] (fput+0x114/0x210) from [<c01e4b2c>] (filp_close+0x58/0x64) [<c01e4b2c>] (filp_close+0x58/0x64) from [<c018262c>] (put_files_struct+0xb8/0x1 60) [<c018262c>] (put_files_struct+0xb8/0x160) from [<c0182910>] (do_exit+0x194/0x66 4) [<c0182910>] (do_exit+0x194/0x664) from [<c018310c>] (do_group_exit+0xb0/0xe4) [<c018310c>] (do_group_exit+0xb0/0xe4) from [<c018dd20>] (get_signal_to_deliver+ 0x3c4/0x420) [<c018dd20>] (get_signal_to_deliver+0x3c4/0x420) from [<c01684ec>] (do_signal+0x 68/0x65c) [<c01684ec>] (do_signal+0x68/0x65c) from [<c01690bc>] (do_notify_resume+0x18/0x4 8) [<c01690bc>] (do_notify_resume+0x18/0x48) from [<c0165eb8>] (work_pending+0x24/0 x28) ---[ end trace 7433969f0698b415 ]--- request_suspend_state: wakeup (0->0) at 67152794365 (1970-01-02 00:00:32.4688848 60 UTC) init: untracked pid 1264 exited init: untracked pid 1263 exited request_suspend_state: wakeup (0->0) at 88737002587 (1970-01-02 00:00:54.0530935 63 UTC) init: untracked pid 1311 exited init: untracked pid 1312 exited / # -------------------- I've tried several bootloaders, like superboot-20110727.bin and u-boot_nand-ram256.bin. I'm not posting separate errors, because as most of the OSs fail, with default parameters, I assume I must be doing something wrong in general. Does anyone have an idea of what it could be? This is my FriendlyARM.ini -------------------- #This line cannot be removed. by FriendlyARM(www.arm9.net) LCD-Mode = Yes LCD-Type = N43 CheckOneButton=No Action=run OS=Android VerifyNandWrite=Yes StatusType = Beeper| LED #################### Linux ##################### Linux-BootLoader = Linux/superboot-20110727.bin Linux-Kernel = Linux/zImage_n43 Linux-CommandLine = root=ubi0:FriendlyARM-root ubi.mtd=2 rootfstype=ubifs init=/linuxrc console=ttySAC0,115200 Linux-RootFs-InstallImage = Linux/rootfs_qtopia_qt4-slc.ubi Linux-RootFs-RunImage = Linux/rootfs_qtopia_qt4.ext3 ################### Android #################### #Android-BootLoader = Android/superboot-20110727.bin #Android-BootLoader = Linux/u-boot_nand-ram256.bin Android-BootLoader = Linux/u-boot_sd-ram128.bin Android-Kernel = Android/azImage_n43 Android-CommandLine = root=ubi0:FriendlyARM-root ubi.mtd=2 rootfstype=ubifs init=/linuxrc console=ttySAC0,115200 androidboot.console=s3c2410_serial0 Android-RootFs-InstallImage = Android/rootfs_android-slc.ubi Android-RootFs-RunImage = Android/rootfs_android.ext3 ################### WindowsCE6 ################# WindowsCE6-Bootloader= superboot-20110727.bin #WindowsCE6-Bootloader= WindowsCE6\NBOOT_N43-RAM256.nb0 WindowsCE6-BootLogo = WindowsCE6\bootlogo.bmp WindowsCE6-InstallImage = WindowsCE6\NK_n43-i.bin WindowsCE6-RunImage = WindowsCE6\NK_n43-i.bin #################### Ubuntu ##################### #Ubuntu-BootLoader = superboot-20110727.bin #Ubuntu-BootLoader = Ubuntu/u-boot_nand-ram128.bin Ubuntu-BootLoader = Ubuntu/u-boot_sd-ram128.bin Ubuntu-Kernel = Ubuntu/uzImage_n43 Ubuntu-CommandLine = root=ubi0:FriendlyARM-root ubi.mtd=2 rootfstype=ubifs init=/linuxrc console=ttySAC0,115200 Ubuntu-RootFs-InstallImage = Ubuntu/rootfs_ubuntu-slc.ubi Ubuntu-RootFs-RunImage = Ubuntu/rootfs_ubuntu.ext3 ############### UserBin ################# #UserBin-Image=WindowsCE6/NK_N43-i.nb0 #UserBin-Image=BasicOS/demo.bin UserBin-Image=Games/SuperMarioWar/zImage_n43 #UserBin-Image=Games/SuperMarioWar/u-boot_nand-ram256.bin UserBin-StartAddress=50100000 --------------------
Most OSs from the DVD2/images fail to run
Hi I also got a Tiny6410 with a 7" display and have the same problem as you. I also downloaded the Tiny6410B20111022.iso from the friendlyarm ftp server-> same thing: installation well but running failed. I still have no solution...
Is the supervivi in the images directory the same as in your script file? According to your listing above, it must be superboot-20110727.bin When you run SD-Flasher, do you "Fuse" version superboot-20110727.bin ?
Do you have 2G NAND? It is MLC and you must use the images that have MLC not SLC suffix. Make sure they are on the Sd card and edit the .ini file.
Hi I succeed now with booting from the 2GB Nand MLC2, which is on the latest Tiny6410 board. I put the superboot 20110722 on the SD card to start the download menu (option CheckOneButton=yes) and than I manually download the files via USB on a Windows XP and the DNW tool. The file which worked was the u-boot_nand-ram256.bin (which I created myself), superboot-xy.bin didn't work (versions tested 20110722, 20110826, 20111102). Now I can run linux from the Nand and can go on further...
