Hi everybody Does qtopia linux support the java programs? Does anybody know that? i want to run java programs but i couldn't run it in mini6410. if java doesn't run in qtopia linux , what kind of programing languages must i use to make visual programs. Thanks for your attention.
run java programs in mini6410
qtopia != linux. You can run qtopia on a linux based system or you can run everything different. If you run a JavaVM on your Mini2440 you can run your Java programs. If you want to go with GUI programs, I may use C++ and the Qt library (without the overhead of qtopia, if you do not need it)
